Help with Dell PFS extractor
    Hello,I'm trying to extract dell BIOS from the firmware update from Dell support but each time i drag and drop the BIOS on Dell PFS extractor,I get an error message.
    Is there something I'm not doing well or i need to download something else before i can extract?
    Re: Help with Dell PFS extractor
    try this..
      Originally posted by peste View Post
      try this..
      Thanks,I'll try it and post the outcome here.
        I'm getting the same error message.
          Upload your file here.
          Become a Badcaps supporter
          Thanks to all supporters.
            PFS Extractor 4.9 will do it.
            Thanks to Plato Mavropoulos for all the great software https://github.com/platomav
            • stars.4u
              stars.4u commented
              Editing a comment
              thanx bro.
            Thanks i really appreciate,it work fine.
            thanks to everyone that contributed,i appreciate for taking out time to comment.
              hi bro
              I am facing this error
                Originally posted by ali.nb66 View Post
                hi bro
                Its a different type,it will not extract using PFS extractor.
                Firstly you can extract a rom file by using the command line
                Alienware_m15_R2_m17_R2_1.16.1.EXE /writeromfile
                The rom will be written,then it needs editing to the correct size. You can use AMI_PFAT_EXTRACT software to remove the PFAT header,it will not remove the end part (footer) so it will need further editing with a hex editor. It isn`t a full bios image,it is only a bios update !
                    please where do i get the extracted file?
                      https://www.badcaps.net/forum/showpo...95&postcount=6
                        this is what i am getting?
                        my first time using it
                          YOU FIND THE EXTRACTED FILE AT THE SAME FOLDER OF Dell PFS extractor
                          Or if you want make a folder , put the dell exe and Dell PFS extractor in , than drag and drop the exe at Dell PFS extractor exe you will get the extracted files
                            Thank you so much
                            Help me to bring my notebook alive again
                              i am loving it,works fine for me...
                                I have a problem. I got message . . Done! But no file is created. I was searched for it manually, nothing. I changed folder, i changed bios, i changed extractor. Every time i got Done! But no file is created. Whats the problem? I searched that python is needed so i installed it but nothing changed
                                  Make a folder that contain bios + pfs extractor and try
                                  https://www.youtube.com/watch?v=nZ3gRlI0bvw&t=71s
                                    Same story, changing partition with one folder including both files same story, running as administrator same story, changing names of bios files same story
                                    Is Windows 10 Home a problem, maybe that should be a pro version?
                                    I tried extractor from here and from labone site
                                      post a link to the bios you`re trying to extract
