HP Elitebook 840 G5 Black Screen
    Hey there,
    I have got a HP Elitebook from a friend. It just starts with a black screen and loud fan. He tried to unlock the BIOS. Strangely I can't get 2 same reads out of the 32 MB Chip.
    If I put another Chip in I can read and write on it without any problems. So I suggest it is a bad chip.
    I only got a faulty readout of the 32 MB. The original dump and the one that was flashed is sadly gone forever. But maybe someone can make a working image again out of it?
    Thanks a lot in advance
    filewalker
    Re: HP Elitebook 840 G5 Black Screen
      Originally posted by filewalker View Post
      Hey there,
      filewalker
      I have rebuilt your original bios, write both chips with these files and copy the result.
        Thank you aboumohamed and aldopc,
        I tried your files and they did not work. I still get a black screen with the fan spinning.
        I had to replace the 32 MB Chip since I was not able to read/write on the old one.
          HP EliteBook 840 G5 Base Model Notebook PC
          Become a Badcaps supporter
          Thanks to all supporters.
            What programmer do you use? I think you have a problem with that...
              I have a CH341A Programmer. Not the best and I am planning to buy a better one, but in the meantime I have just flashed 8x 840 G3. And with the new chip I was able to perform a proper write and read. I think the friend who tried to unlock it did more damage to it doing so.
                Hp 840 g5 bios corrupt help!!
                Help with corrupt bios Hp 840 g5,fan spin no display. I add orig bios.
                SN:5cg83562sz
                Thanks.
                  Anyone to help!!!
                  thanks
                    Re: Hp 840 g5 bios corrupt help!!
                    SN:5cg83562sz
                    Thanks.
                    Here's your New BIOS, try it and let me know.
                    all donations are welcome,
                      I'll try and let you know.
                        I try new bios,not working.Fan spin max,no display.
                          Ok, Cvejas write both chips with these files (16mb and 32mb)
                            ok,I'll try and let you know.
                              Hellow mates .
                              I have they same problem, amber light blinking at power LED
                              i need clean bin file
                              here is my dump file
                                hp elitebook 840 g5 no display
                                board number computro-6050A3079801-mb-A01(A1)
                                no display
                                i have attach bios to clear me
                                  So I have 20 of these things my wife got and decided to give them to kids... unfortunately, all 20 are bios locked
                                  I have an RT809F programmer and extracted the bios 32mb bios.
                                  I used the HP Bios unlock tool and then wrote back the bios but now the caps lock light blinks then the fan runs high.
                                  I wrote back the original bios and the same issue
                                  Question
                                  1. Do I need to read and reprogram both 16mb and 32mb chips? My understanding from reading all I need to do is just the 32mb
                                    If all I have to do is just the 32mb why did it fail?
                                  2. Since I have 20 840 g5 is there generic firmware(s) I can use to just write to all and re-input serial numbers etc?
                                    If so are there detailed steps for this?
                                    Device: laptop
                                    Brand:hp
                                    Model: 840 g5
                                    Board : 6050A2945601-mb-a01
                                    REQUEST: clear me Bios
                                      Originally posted by cekwork10 View Post
                                      Device: laptop
                                      Brand:hp
                                      Model: 840 g5
                                      clear me bios ? ,you mean clean the ME firmware, or remove a password or... ?
                                        Hi, I have a 840 G5 that had black screen and fan speed max, I've found a bios files 16 and 32 that works, but after to flash I have a security error on start "HP EndPoint Security Controller Problem"
                                        , I've tried to resolve with hp dmi tool but it don't works. Now I have a wrong serial and I think also wrong security o something like wrong mac address. I've attached the original files, can someone help me to solve this issue?
                                        Serial Number : 5CG9154WPG
                                        Product Number : 2FA66AV
                                        Description : HP EliteBook 840/846 G5
                                        BID = 17WWCSCT601#SABZ#DABZ
                                        FEATUREBYTE = 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqhKhkjh.F5
