Hisense 50P6
    Re: Hisense 50P6
    Thanks Diah
    Signature:Seemingly hopeless tv fixer
      Re: Hisense 50P6
      you may find the 17 blinks is normal and not an actual fault indication, assuming this is a smart tv.
      Under normal operation when power is 1st applied it will prob flash 17 times, then after from stby will prob only flash once or twice.
        Re: Hisense 50P6
        Possible I suppose, but seems excessive to me if it is a normal thing.
        Cannot find any firmware for any Hisense TV on their Australian site, so I have sent an email to their support site asking them to provide me with a download or link to the firmware.
          Re: Hisense 50P6
          No way at cold start TV blink 17 time... the most count will be 4-5 as each blink described as one script lunch from Firmware.. this why it could be there are cliché at firmware or emmc fault.
            Re: Hisense 50P6
            Still no response from Hisense Australia re some firmware.
            I have sent a second request.
              Re: Hisense 50P6
              who in urgent need to repair his Hisense ... need to call them... so thier understanding.
              Call them and ready yours serial lable as printed on the back of the TV.
                Re: Hisense 50P6
                OK...will ring them next business hours.....thanks
                  Re: Hisense 50P6
                  I have been in touch with Hisense via phone.
                  As advised by Diah, they asked for the serial number, my name, address, model number, email addy eyc.
                  They say it will take them 2-3 business days, as they send updates of firmware only of an AM.
                  So I will update everyone in about 5 days I guess, as the weekend is nearly here in Australia.
                  Thank you.
                    Re: Hisense 50P6
                    I have just received the email. with the updated firmware.
                    Instructions are:
                    The software provided is the latest version available. It should only be used for updating
                    HISENSE television units with matching Model and Serial number.
                    Instructions:
                    1. When TV is on, unplug Power Cord on the back of TV.
                    2. Plug in USB stick with Upgrade Firmware into TV USB port
                    3. Hold the POWER button on remote control and at the same time turn on the
                    TV by connecting the Power Cord back. Release POWER button on remote
                    control only when you see ‘Software Updating' on TV.
                    4. TV will then update automatically, and restart when update complete
                    Important: Do not interrupt the update; do not use the remote control and
                    keep the unit ON all the time.
                    5. Remove the USB memory key.
                    6. Press Quick Setup button on remote, go to
                    Settings -> Support- >Restore To Factory
                    Default. Then follow the installation guide to finish setting up the TV.
                    My problems...
                    Ala
                    3) with no remote, I figure I just use the sets main power button?
                    6) No remote to press "Quick setup,Settings -> Support- >Restore To Factory Default.
                    I do have a Harmony 300 remote, so I went to Logitech, entered the Hisense 50P6 info , and it located a code, I downloaded it onto the remote, but it does not have any assignments for buttons....
                    MENU, QUICK SETUP, FAST ACCESS TO ALL APPLICATIONS, HOME.
                    The original remote model from Hisense is EN2B27.
                    I have raised a ticket number with Logitech requesting if any other codes they have for Hisense tv's have these remote functions, and am awaiting their response.
                    Thank you.
                      Re: Hisense 50P6
                      did you played the firmware..... many android apk are free can handle full rc on all model. just need mobile with IR sender.... they are better than any other universal RC in market.
                        Re: Hisense 50P6
                        Remotes: https://www.ebay.com.au/sch/i.html?_...acat=0&_sop=15
                          Re: Hisense 50P6
                          Sorry for the long delay.
                          I got hold of the firmware from Hisense Australia, transferred it to the USB stick and inserted into the USB port of the Hisense
                          Held down the power button for 60 seconds, then turned on at the PowerPoint, held power on/off for another 60 seconds, however, all that keeps happening is that the screen turns on displaying these lines again
                          Tried many times, but it just won't boot into the USB update
                          The diffence now though, is that the power button no longer does the 17 blinks, and now does 4 as it turns on and keeps showing the lines, with the lines slowly shifting to the left of the tv as you look at it
                            Re: Hisense 50P6
                            Missing pictures
                              Re: Hisense 50P6
                              I have tried all those suggestions that you see on google for resetting the tv...eg, hold down power button, disconnect etc....none of them does anything and all I am left with is that the telly turns on, goes to these lines, and responds to nothing other than the power on/off button on the remote.
                              I am using a Harmony remote, and Logitech sent me an exact file to synch onto it.
                              The file on the usb stick simply won't boot.
                              Have I reached the stage where I need to give in?
                              ps...this is what I am doing with update firmware ......I wonder if I am doing it right?
                              https://i.imgur.com/TIf0fos.jpg
                                Re: Hisense 50P6
                                Here is some firmware if it helps someone?
                                https://hisenseaus-my.sharepoint.com...6%2FJ0423&ga=1
                                  Re: Hisense 50P6
                                  Wrong!
                                    Re: Hisense 50P6
                                    1- usb formatted as FAT32 MBR mode
                                    2- the first file with format .pkg dont extract it. just copy it on the stick
                                    3- you may need to rename the file upgrade_loader.pkg in case didnt start
                                    4- no need 60 second. as son you press power on RC and keep press plug the tv in wall
                                    5-insert the USB at USB Ver2 ( black socket at the side of the TV
                                      Re: Hisense 50P6
                                      Originally posted by lotas View Post
                                      Wrong!
                                      It would be appreciated if you could tell me the right way?
                                      EDIT
                                      Thanks Diah
                                        Re: Hisense 50P6
                                        When I right click the file,(my link) it will only allow these options
                                        Preview
                                        Download
                                        Copy to
                                        Details
                                        If I select Copy to...I can't seem to save it
                                        If I download it, it turns into this zip folder
                                        If I extract then, it just comes back with all those folders again.
                                        My apology for not understanding how to simply grab that one file
                                        HELP....
                                          Re: Hisense 50P6
                                          How bout, left click hold, drag and drop, send to should also work.
