Re: Philps QLED Q60B Model:QE65Q60BAU
Instruction
Attention !
Everything you do - you do at your own peril and risk!
1. Format USB flash drive (FAT32 only) and standard cluster size.
2. Copy the downloaded file (upgrade_loader.pkg) to the root directory of the USB drive.
3. Unplug the power cable from the outlet
4. Insert a USB flash drive into a USB 2.0 port. If the firmware does not start, insert into the USB 3.0 port (USB 3 port is blue)
5. Plug the power cord into a power outlet.
6. You should get a message on the screen that says "Software update in progress" - this will remain on the screen until it completes.
(I didn’t have this, it was just a black screen. Don’t be scared, the firmware is coming, you just need to wait 15-20 minutes)
7. Once the software is installed and the TV has completely rebooted, do a complete "Reinstall TV via menu" > "Setup" > "All settings" > "General settings" > "Reinstall TV" > "OK"
(I didn’t reboot on my own. There was a black screen and the Ambilight backlight turned green, I rebooted already from the remote control)
Instruction
Attention !
