Good afternoon! Let's see if anyone knows who can help me with this. attached photos. sometimes these strange black figures appear on the panel, in various areas. I have never seen this error. thank you
Samsung UE43RU7406 strange black figures
Re: Samsung UE43RU7406 strange black figures
Originally posted by Diah View Postno one can answer yours questions.. only you self... if the this black line /points move up and down when you click on screen then its dirt under the glass if not then its panel burn cells.
thanks for answering. those strange figures appear and disappear, and different ones appear in another area. I think it can't be that. I forgot to put that information
Thank you all for the answers. How could I rule out panel or main? I have thought about disconnecting a flat cable from the 2 that go to the panel, to see what happens. and then another. If the failure is in both cases, it could be the main board, and if it only fails in one of the 2 cases, it would be the panel. is it a good strategy? thank you
Originally posted by ducky29 View PostI think its a software issue. Usually emmc goes faulty. Pretty sure a new mainboard would solve this problem.
Usually the menus are scrambled with big and assorted letters.
Hello! Thank you very much for answering. I also think it could be a problem with the main board. Do you know any easy test to make sure? On the other hand, he located a main board, but it is a later version of the tv model, and it has a different bn94 code. it will work?
Originally posted by Diah View Postthe best way log in service menu.. if service menu displayed complete over the black spot then its software.. and you can from service menu do factory reset.
Unfortunately, on the screen of the service menu, the errors continue to appear. Is it a sign of panel failure?Last edited by Raulnn; 05-11-2023, 11:56 AM.
Originally posted by Davi.p View Postma bastaaaaaaaaa.....!
maybe a failing update, have you ordered a spare main board? What do you wait?
There's no need of any test at all, this discussion about if it's the panel or the main board is by beginners, the screen doesn't interpret any thing in any way about what's inside the image, so it can't invent to misshape a character font!!! I don't believe there are so many posts in this thread, some one must review its knowledge..
