help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
    LA-K771P REV:1.0
    UK2- UH7
    Re: help I need clean bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
    LA-K771P REV:1.0
    UK2- UH7
    Upload your bios backup, add serial number and issue description.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Re: help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
      Hello, the file is not working, thanks
      Who has a new dump
        hello you have me region
          Hello all, Could someone please unlock these bios files.
          I had a go with HPUnlocker I have used this before with no luck
          I am just not confident with this app maybe I am wrong and it would work.
          Fury G8 LA-K771P REV:1.0, Original locked dumps.
          Thanks so much.
            Thanks so much.
              Thank you so much Vesko356, Will give an update when I am done.
                Thanks mate the system is working fine. only just got around to finishing the job.
                  Hello, can you help me to unlock, I tried with file #6 but I get an endpoint error
                    What type of lock do you mean, because I can't see any admin, power-on or user password set in your dump. Absolute persistence module is also disabled...?
                    Upload an image of the password prompt screen.
                      here!
                        here!
                        What's the printed laptop serial number?
                        Are you sure you didn't amend the dump in some way?
                          Cnd2203kyw
                            OK. the serial number match the one in the dump itself, but you didn't answer my previous question:
                              The equipment came to my hands as it is, the BIOS is not physically intervened, I only extracted the BIN
                                ОK, program only the attached dump below, leave the other as is. At first boot enter the bios and reset to factory defaults, then reset security settings to default:
                                  thanks!!!, it works now without endpoint error
                                    You're welcome.
                                      Hi, I have HP Zbook Fury G8 with admin password.
                                      Serial# CND2203G2Y
                                      BIN file is attached.
                                      Thank you.
                                        Serial# CND2203G2Y
                                        Thank you.
                                        Upload the dump from the second chip.
