hi I have a PS4 model cuh-1216A that does not sync the controllers. Better to say cold sometimes everything works correctly but when I turn it off and on again after a while it no longer synchronizes the controllers. It must be said that the Wifi has not worked for some time and so I proceeded to replace the AW-nb218 chip, unfortunately without solving either problem. Controllers plugged into the USB charge fine and always work in safe mode. can anyone help me to solve?
PS4 not sync the controller
Re: PS4 not sync the controller
https://www.badcaps.net/forum/showthread.php?t=50682
https://www.badcaps.net/forum/showthread.php?t=55263
Update. The ps4 a year ago could not be updated, gave an error code and was taken to assistance. Upon pick up I was told everything was working except the WIFI. Since it suited me I confirmed the repair, but I don't know what they did. This is a necessary explanation.
Now I started the PS4 in safe mode the controller connected with the wire as indicated works and I performed an installation. To my amazement from a moment before the controllers didn't work now after the reinstallation everything works ok (except the WIFI).
I'm keeping it under test and since I reinstalled the controllers are working fine. Since I already had some doubts about the HW failure before replacing the BT/WIFI chip and also the firmware problem, what could it be?
