DELL INSPIRON 5593 FDI45 la-j091p no power on
    Hi all, kindly asking for advise.
    owner tried to install a stick of ram and the does laptop does not powers on.
    the only schematic i found is here
    the charger IC is ISL 95522H and it is getting very hot.
    without battery
    DCIN is 17.4V
    ACIN is 2.4V
    VDD is 0.4
    CMSRC 0
    main power rail is missing power.
    Do you think charger IC is dead ?
    Re: DELL INSPIRON 5593 FDI45 la-j091p no power on
    Sir you check the main Func = 3.3VALWP / 5VALWP if shorted
      resistance on all coils is pretty high except for the near GPU coils which is about 3 ohms
        Measure the voltage to ground on each pin of the dual diode at PDB01.
        Also at each pin of the DCin mosfet at PQB11.
        Source (1-2-3)
        Gate (4)
        Drain (5-6-7-8)
          Hi mon2 , thanks for your reply and help
          Buy chance can you point me the the area of those components, the brdv i have is not correct
            See attached. Found this (if it is correct) by searching for '5593'.
              Found this diode butbit is a single diode
              Do you think this is it?
              I think that The suggested schematics is not exactly for this board
                PQB11 = mosfet and should be 8 pins.
                Post a pic of your logic board. Perhaps have a suitable BV file but it is locked to my sub but it may help.
                  I was talking about the double diode
                  Here is the board pics with the best light i have
                    Which double diode? Can you point to it on the motherboard?
                      Source (1-2-3)
                      Gate (4)
                      Drain (5-6-7-8)
                      I think we have a confusion.
                      Here you ask me to measure voltage on the dual diode, and i called it double diode. but i cannot find such dual diode
                      instead i have found a single diode on PDB01. as visible in picture on post #7.
                        As per post#1, VDD on charger ic is 0.4V .What is the exact resistance here? What about ACOK on charger IC?
                          Hi
                          Resistance on VDD is 2 ohms
                          voltage on ACOK is 0.09v
                          resistance on ACOK 12 ohms
                            Did you measure without power present? If yes, you indeed seem to deal with a shorted charging controller. It does not fit to the shared history though.
                            FairRepair on YouTube
                              Hi, I am always measure resistance without power
                              I have subscribed to your channel looks good
                                Originally posted by koby058 View Post
                                Hi
                                Remove the charger IC and measure these same resistance to GND again.
                                  Hi
                                  I have replaced this charger IC and now the laptop turns on but the charger IC is still getting very hot,
                                  How can i continue inspection of the issue ?
                                    Just move around the charging controller in Ohms mode and see whether there is still a short to GND present. And next time you need to do that after you have removed the old one but before soldering the replacement. Sanity checks.
                                      Hi
                                      I have measured resistance on all pins of this charger IC, the lowest was 40 ohms some pins was OL.
                                      i can see that the laptop is back to the same state the owner explained to me.
                                      where the laptops starts and working very slow and no charging
                                      Any other advise ?
                                        No, 40 Ohms are bad. You didn't realize? Share where you measured the low values and how much exactly.
