TV Philips 43PUS8505/12 - horizontal line and picture jumping
    TV is Philips 43PUS8505/12, bought in 12/2020, so the two-year warranty has expired about 5 mounth ago...
    Problem is that 15 minutes after TV is turned on, the horizontal lines appear and picture start jumping up and down.
    I suspect that T-CON is faulty when wormed up...
    I separated all the cables from the T-CON and cleaned them but there is no change.
    Eco mode is disabled, software is up to date, I make factory reset and reinstal TV from TV menu...no change, problem is stil here.
    Anibody have some thoughts?
    Re: TV Philips 43PUS8505/12 - horizontal line and picture jumping
    The name of the display ?
      Here are the pictures of the stickers...
        Try to disconnect on one side of the tcon and look at the image
          I tried that with both cables, after few minutes same error appears.
            Check the temperature D001-003
              can`t find this on my tv...
                Have you looked at this plats ?
                  I replaced T-CON board and problem is remained.
                  Then I noticed that D007 is very hot when tv is working, so hot that you can`t keep touch it with the finger.
                  When I disconnect cable from T-CON board to the panel board on this side the rest of the picture is ok with no interaptions.
                  When I disconect cable on other side the problem is remaining.
                  So it look like D0007 on panel board on ane side is bad. I can`t find any shorted element with multimeter.
                  Is there any repair possible or not?
                    You carefully remove it (tvs diodes) and that's it, you can remove all the others, they are more problems than good.
                      Will TV work ok without this diode?
                        Yes it will.
                          yes I have 3 RCA's with same problem, nice tv's 4K but lost interest and sure as hell not going to spend hundreds of dollars on replacement parts if not going to solve the problem. Maybe this post will renew my interest to have another look. Have heard a lot about removing useless diodes on several brands like samsung, lg, rca etc and problem solved. Hope it works for you ... will be keeping an eye on this post.
                            I removed this diode and tv is working without errors for now, I tested it for 35 minutes...not quite understand it myself what is this diode for and how tv is working without it but I am satisfied for now...
                            thanks for the advice...
                              diode is tvs .. transient voltage suppressor its there as protection .
