I've seen this board incorrectly refered as EAY4050440, because last digit is a dot in a matrix (see right-bottom corner in attached image). I've always seen "1" marked, so real LG part for 32" is EAY40504401 (LGP32-08H).
For 37" it's EAY40505001 (LGP37-08H), sharing the same PCB, only primary mosfets change.
It can be found in LG 32LG3000-ZA model, among others.
I've found schematic too.
I haven't seen any of these fail of secondary capacitors. They have more subtle failures in primary side.
One common failure is at SMD resistors in series R609, R610, R611, R612 (620kΩ x4 = 2,48MΩ ≈ 1MΩ + 1MΩ + 470kΩ). This affects PFC.
I've one that after some minutes (cold start) it drops AC Detect signal ("ACD") but keeps generating 5V Standby. Haven't found solution to this one yet.
