IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Thank you sir.... I will programm it tommorow and let you know....
      I ask for help.
      Unsuccessfully officially updated the bios.
      Lenovo-V14-ADA
      SN: PF2ME3HR
      MTM: 82C6006DRU
      I really hope that I trimmed the file correctly.
        Originally posted by Donbellozi View Post
        I ask for help.
        Lenovo-V14-ADA
        SN: PF2ME3HR
        MTM: 82C6006DRU
        try post #12... at post #1 you have DMI...
          I ask for help.
          Lenovo-V14-ADA
          SN: PF2ME3HR
          MTM: 82C6006DRU
          Your file is identical to the official virgin bios, so it should works fine.
          all donations are welcome,
            Re: Lenovo V15-ADA NM-D151 Rev 1.0
            Dump working Thank you very much
              is this for lenovo v14-ada? can i use eprom programmer to flash?
                if you have the name and model of the laptop as in this thread ... see post #23 ... don't forget before writing the bios chip, to make a copy of the original bios of the laptop..
                  Lenovo IdeaPad 3 15ADA05 - W25Q64FW_1.8V
                  If anyone has a working W25Q64FW_1.8V bin for Lenovo IdeaPad 3 15ADA05 (PF2ZBYDY) please share. Attached is the existing one I read.
                    Re: Lenovo IdeaPad 3 15ADA05 - W25Q64FW_1.8V
                    Originally posted by selpa8 View Post
                    If anyone has a working W25Q64FW_1.8V bin for Lenovo IdeaPad 3 15ADA05. Please share. Attached is the existing one I read.
                    Write your Serial Number.
                      Serial: PF2ZBYDY
                        Here's your New Bios file, it's a Virgin Bios from Lenovo with your DMI.
                          Thanks, but didn't work (no post, no logo, novo button doesn't work).
                            It's a Virgin Bios it should works fine, maybe you have something else (Hardware Issue).
                              IdeaPad3 15ADA05 bricked after Bios Update
                              Subject: Bricked Lenovo IdeaPad 15ADA05 after BIOS update - SN PF2NSx4y
                              I need help with my bricked Lenovo IdeaPad 15ADA05 (SN: PF2NSx4y). I've tried turning it off and on, disconnecting the CMOS battery, and all the other standard fixes for 5 hours now and nothing is working.
                              I need a solution to this problem, otherwise this laptop is just a paperweight. Can someone help me out here?
                                Re: IdeaPad3 15ADA05 bricked after Bios Update
                                post the original bios of the laptop..
                                  How can i upload the Bios of my Laptop? i cant even turn it on.Just the Fan is Running and the Power LED is lid.
                                    Did you try pressing in the NOVO button ? .If that hasn`t worked besides the other standard fixes then your only option is to program the bios. If you don`t think its something you can do yourself take it to a repair shop
                                      Here's your new bios file, it's a virgin Bios from Lenovo with your DMI.
                                      Thank you sir it's ok
                                        Good to know, You're Welcome.
                                          Blinking Power Button on Lenovo IdeaPad 3 15ADA05 GS450/GS550&GS750 NM-C821 Rev 1.0
                                          Completely lost here. Have this Lenovo GS450/GS550&GS750 NM-C821 Rev 1.0, which turns on sometimes and works ok, and I can go to bios, although the power button is flashing.
                                          Other times it will just won't pull any current above 0.01A from the PSU, ON LED is lit up and the power button flashing.
                                          I have tried to flash this bios via SPI https://www.badcaps.net/forum/showth...ighlight=GS550 it fired up and informed that needs to reser nVRAM and wont keep TPM settings and just hanged there. After restart no picture as with the original bios.
                                          I have Reverted the original bios and loaded up at first when I resoldered the BIOS (i went to BIOS and reset to defaults), then on reboot won't turn on or will pull 0.6A but won't show any picture or keyboard response.
                                          I am attaching the DUMP in case you find issues with it.
                                          I must add, no liquid damage or corrosion on the board or foul play.
