IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Hi there,
    V15-ADA 82C7 power on, charging, fan spinning but remain on blank screen (the same on HDMI out). The original dump attached, but i can't extract de Windows key with BIOSdump2license.exe (serial encrypted mesage for a short time).
    So... can anyone patch the latest BIOS: https://download.lenovo.com/consumer...s/e8cn39ww.exe for Serial: PF328XV4 and MTM: 82C7008TIX?
    Thank you in advance!
      Originally posted by onepic View Post
      Hi there,
      did you read post #1?
        Yes, but i don't want to made mistakes, because i do not have too much experience with. So is forbidden to ask some one else to help? If yes then plese delele my posts.
          I have patched it by myself, write it into the bios chip but still into the black screen... Can anyone verify it the patched BIOS it's should be ok with the data posted above? Thank you!
            Its verified OK, you did a good job. Its worth trying an older version as well,and if that doesn`t work start looking for a hardware problem.
              Thank you it's working
                Unfortunately the same, also with a a BIOS from august 2022 . So it must be a hw problem.
                  Hello all, can somebody help me for a supposed bios issue (black screen)
                  Model : lenovo ideapad 15ada05 /
                  Lenovo new Bios url : https://pcsupport.lenovo.com/fr/fr/p...loads/ds543481
                  Chip is a Winbond 64n the new bios is too big
                  1. here is the backup chip desoldered from board (no clip ^^) :
                  2. The new one, downloaded from lenovo, and extracted :
                  When i try reprogramming (ch341blackedition), he say too big
                  What did i can do ? Thank for your time
                    Originally posted by narpa View Post
                    Hello all...
                    Everything you need is explained in detail in post #1
                    You can download an already extracted from the update bios dump at posts #3, #12 or #20
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                      Ok I extracted and modified the bios like post number 1, good size now. Programming was ok, I tried multiple bios file but always black screen, not a bios issue for me.
                      Thank for your time, we can't fix them all
                      Info : for this model chip Winbond 25Q64FWSIG 1.8v i used an adapter 1.8v 25xx flash for ch341.
                        Originally posted by peste View Post
                        you have everything you need for post#1, if it doesn't work it means you are writing the bios with errors...what programmer do you have??
                        Well I have a CH341
                          lenovo nm-D151 rev 1.0 gv451 gv 551 bios dump
                          hi, I have this lenovo that turns on the fan and the LED when I turn it on, the screen seems to start up but then goes dark, I tried some bios files but I don't know if they are compatible, I am attaching the original backup, thanks
                          the chip bios is winbond 25q64fw 1.8v
                            Re: lenovo nm-D151 rev 1.0 gv451 gv 551 bios dump
                            Go to the lenovo support site,enter the laptop serial number.Find the bios update listed under drivers. If the bios version is E8CN**WW (** is the version number) then yes they are compatible.
                              from the site the version is E8CN39WW
                                Everything you need is in this thread.
                                  can i use E8CN36WW?
                                    can i use E8CN36WW?
                                    Yes.It is older though, version 36. If you want to use the newest there`s a link to a guide guide at post #1 showing how to extract it yourself from the update exe.
                                      Hello, Lenovo V15-ADA / Model no: 82C7
                                      S/N: PF203BYH
                                      MTM:82C7001HTX
                                      there is an image harddisk and nvme does not see it ?
                                      Can you send the bios file?
                                        S/N: PF203BYH
                                        MTM:82C7001HTX
                                        read post #23, but first make a copy of the original bios..
                                          Originally posted by hardware1 View Post
                                          Here's your new bios file, it's a virgin Bios from Lenovo with your DMI.
                                          Ryzen1234;1246821]can you help me
                                          this is my old bios
                                          Model Name : 82c6
                                          Serial Number: PF3A9JRS
                                          MTM: 82C600BLAU
