I just picked up the same tv with the same problem. When I unplug the ribbon marked in red, the tv will display a good image on the screen side marked in red. When I unplug the other ribbon the image is full of crap and kind of dissipates. Bud, do you think it is only a bad tcon? I do get 12.6v on both sides of the fuse.
I would check the resistance of the caps on the tab bonding board, if none of them show <100 Ohms or so then you can try taping off method.
I also have a Samsung un50h6350 tv with no picture and maybe no sound (later explained).
When i power it on, the tv standby light will blink 6 times and then the tv stays powered on but still no picture. No sounds are heard when pushing remote but i was able to blindly navigate i believe to the sound diagnosis tab and then i was able to hear the music playing but still no picture. The backlights all light up and the t-con board has 2 blue led lights. One is labeled led1 and the other is labeled led 2. I did find another led3 on the board but it doesn't light up. I ordered another t-con board and exact same symptoms with 6 blinks, backlight on and only 2 led lights on t-con board. If the backlight is functioning could it still be a bad power supply or possible main board or is it likely the panel diverter board (which I assume is too expensive of a fix. Any help appreciated.
I would have started a new thread, but being a noobe apparently I am not allowed yet.
Additional testing. I disconnected the left ribbon cable going from t-con to panel and now the 3rd led light on t-con board lights up and it shows half a picture. Connecting the ribbon cable back up and disconnecting the other one results in the tv displaying the original symptoms of back light on and no picture.
Repaired this set - tape method. after many tries - best solution was masking pin 2 and 3 on lvds ribbon cable on Tcon board side. It does have the faint horizontal lines if you look very close at the top of the screen. Not a perfect picture but not bad from a distance. Good enough for me !
