Hi folks,
I have this TV PS-42Q96HD DYP-42W2PLUS in for repair, PSU is clicking - cycling every 2 seconds. Have checked all caps with esr meter and and replaced a few that were visibly bulged, reading high, and one that had completely failed. With mains applied, psu starts clicking and Vs is measuring at 304 - 306v (too high, should be 205!) With oscilloscope i can see Vs flies up to 300v+ then falls as relays click out, then climbs again. Disconnecting from the panel, with psu on bench, Have added resistors to back of board to force PSU on and Vs on. Vs then sits up at 304v constantly, no relay cycling. Va is at 63v just as it should be. Has anybody seen this issue before with Vs being well over voltage? Anyone have an idea what it may be? I wonder it there is over voltage protection that is kicking in, hence the click cycling? Is it likely to have damaged the y-sus board?
Bob
Bob
