dell se198wfpf repair
    Hello
    I have a monitor that recently blew up when plugged in.
    There was a pop and then then wonderful smell.
    Upon opening the case and removing the board, there is zero visible damage.
    I suspect the fuse blew.
    Does anyone have a quick fix or possible ideas for fixing this.
    I live in a tiny town- and I can guarantee I will not be able to source parts here.
    I will probably need to order parts.
    The search yielded results, but all posts contained boards that had visible damage. I see nothing.
    The monitor is dead - without any sign of life whatsoever.
    Thank you
    ----------------------------below is my normal typing style----------
    hey..
    plugged in pop - smell
    board looks fine
    thinking maybe just the fuse blue ?
    thoughts? ideas -
    black screen - no led
    Re: dell se198wfpf repair
    1) A good fuse should measure less than 1.0 ohms.
    2) Check your bridge rectifier for shorts.
    3) Check your power mosfet for shorts.
    4) If you don't know what #2 and #3 are, post a picture of your board following the instructions below exactly.
    #2 and #3 are the most likely candidates to take out the fuse.
    If you wrote in that style above, I would not taken the time to answer. Many others here would have done the same and moved onto the next thread. This is not twitter or some phone text forum.
    And NO, I'm not grumpy or an English major, but think, garbage in, garbage out.
    --- begin sig file ---
    --- end sig file ---
      wow - i have been away for a bit
      just to think about it - - i think it is a fuse
      i will go check the forum rules - i usually do - because i have come acrooss lots of
      enal type - so as i say - englidh ust must be
      Her Majesty the Queen of England's english ...
      same reply as alwways
      if you are her - i will be more than happy to use the queens english
      iii if yu are just a "queen" - i may even consider that - too. ( 2 )
      but like i said - i usually check the forum rules -
      ifr it ain't in da rulez den it ain't goonna happn babeeee
        You are now officially on your own. I don't have time to deal with smartasses.
        https://www.badcaps.net/forum/announcement.php?f=24
        Posting rules:
        This forum was created to be a technical support forum primarily for the do-it-yourselfers who choose to repair their own boards. Any and all technical questions are welcome!
        3) Please use COMPLETE sentences, punctuation, and grammar! Nobody is perfect, hence, a spelling error on occasion is no biggie. However, posts/threads that are unreadable will be deleted. This includes any and all forms of 'ebonics', leet crap, chatroom jargon, and 'text message' shorthand and slang. This forum is not a chatroom/text message, please use full words and complete sentences.
          hey..
          board looks fine
          thoughts? ideas -
          that would have simply been deleted....because not only does it make you look like a tard that shouldn't be working on electronics, it drops the overall IQ of the forum a few points.... Seriously? You type like that? That may be the cool thing to do on facebook or some other teenage hangout....but anywhere else in the world, its just laughable gibberish.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            even on facebook it would be bad...
            Learn proper english, use it, and play the BCN game again.
            sigpic
            (Insert witty quote here)
