HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Good news, @RethoricalCheese, your unlocker work wonderfully !!
    The clip of the ch341a was atrocious but I did manage to read twice and write without errors at the end
    So yeah, I can confirm for the others that the hp Z440 with a Winbond 25Q128FVSQ can have is bios password removed
    Many thanks
      HP BIOS unlock tool for ZBook G3
      Hello guys!
      I have a ZBook 17 G3 laptop with Power-On password set - password that I don't know for I've never used it (nor set it explicitly). I've been using my unit for years now, unlocking it with my fingerprint, until new fingerprint driver reinitialized something and removed my fingerprint (and left me with a power-on password I never used nor intended to - HP Client Security tool I used to register my fingerprint for power-on auth also associated windows password with it).
      I know main BIOS (admin) password, but it's of no use for I can't get into BIOS...
      Anyway, my unit has Winbond 25Q128FVSQ chip, mentioned on a few pages in this thread:
      1. This one shows use case I could use (before unfortunate fingerprint removal, there was Bios Administrator user option on power-on authentication screen)
      2. This one is for very similar laptop, though I don't know what was the problem with it...
      Before I try it out, I'd rather ask first, could this unlocker tool help me with the problem I have? These two posts made me think so, but I'd better play it safe... I don't expect any guarantees (would be silly to do so), rather an advice or a guide. Thank you!
        Re: HP BIOS unlock tool for ZBook G3
        Originally posted by ssh View Post
        Hello guys...
        Just upload your bios dump here.
        Become a Badcaps supporter
        Thanks to all supporters.​
          Originally posted by RethoricalCheese View Post
          The tool is doing the job nicely, but not always. Improved version is in development but because I will integrate it into a more automated tool, it will take more time to release the public version.
          Also I am trying to use pogo-pins and 3D printed fixture to read and program wson8 chips. If anybody has a nice design for that, please do let me know.
          Did you succeed in finding a 3d model for printing a case for wson8 chips? If not I will purchase one and copy the design and share the STL model with the forum. Feel free to share adapters that has a good reputation so we can copy something that likely will work
            Many thanks
            Yeah, atrocious is the correct definition. Especially if the chip is wson8
              Originally posted by newbie_unlocker View Post
              Your most likely getting lots of FFFF's because the clip isn't connected properly. I had the exact same model and for me I bought the 8 pin jig from eBay and removed the chip from the board, after that I got perfect reads every time. the ch341a clip is useless and the more times you try and use it tends to do more damage than good.
              as for the software I'll have a look at mine tonight after work and give you a link to where I got my software which works perfectly.
              Please feel free to share the link to the 8 pin jig you bought from ebay.
                I tried to 3d print pogo pin holder but couldn't get it to work properly. It has been easier to just unsolder the chip and place it in the jig.
                  Yeah, I can imagine it might be tricky. I guess so too, relatively easiest way is to unsolder and place it in the jig.
                    Hi Again
                    does hp 840 g5 has any 16mb bios or only have 32mb bios
                      Both.
                        Hello!
                        You can give DMMP BIOS (HP ProBook 450 G7 BIOS S71 dump).
                        On the first and on the second BIOS.
                        Thanks!
                          Both.
                          thanks i found it but when using issi chip unlock not working and get always hp endpoint security error
                            do u have any solution for that
                              Hello!
                              hp endpoint security controller problem.
                              You can fix it. Thanks!
                                Hi fellas. 745 G5 here with bios password. bought a chip on ebay, replaced it, now have 7 blinks and black screen. old chip booted when i put it again, but new chip blinks 7 times. Chip in question is on U367 between ram and ssd, front side of mobo says 25Q128JVPQ with different numbers under that. please help me get it up unlocked
                                  Hey!
                                  You can collect CSME Region in the BIOS. (inside the BIOS file and pure CSME Region)
                                  Thanks!
                                    hi, i need BIOS Q70 (Zbook 15 G5) 32 and 16mb orig
                                    thank all
                                      thank all
                                      Off-topic ,post your request here: https://www.badcaps.net/forum/showthread.php?t=76449
                                        worked for probook 650 g2, Vesko356 helped me with my dump as i had issue with the software. shout out to vesko356 and the software delevoper! helped me loads
                                          I have successfully unlocked the BIOS for HP Elitebook 8440P. I have a couple of laptop that I need to remove the BIOS password and will report back once everything is good. Thanks and appreciate it.
