HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Originally posted by hoaca388 View Post
    Were you able to enter the bios settings before the "HP Endpoint Security Controller Problem" message popped up?
    No. I downloaded the original (Eredeti) BIOS, ran the unlock program, wrote back the new content, and started the machine. I started it several times because it was hard to start. When the screen came up, that's what it said.
    Another question: In what order should the battery, the battery, and the adapter be reconnected?
    thx:szuts
      im going out off my mind! can somebody please help me. i have a hp elitebook 745 g5 and i cant get in to BIOS because of password. can someone walk me through it?
      sigpicGramse
        First you have to buy a device called "Programmer", learn how to use it, use it to dump the bios file in your bios chip, use the forum's automatic RC unlocker to remove the password, write down the bios file ,which password deleted ,back to the device.
        Become a Badcaps supporter
        Thanks to all supporters.
          Okej, guess its kinda like going back to school then. Thanks alot man, really appreciate the help.
          sigpicGramse
            Hey guys, I have an HP Probook g7 i believe. I had to swap out the motherboard for a client and need to change the serial back to the original. I dumped the firmware but it seems the HP bios is encrypted. I can't locate the serial number in HxD as I can typically do. Is there a method for decrypting the bios so I can change the serial?
              Use NbDmiFit : https://www.badcaps.net/forum/showth...light=NbDmiFit
                I have zbook 15 g3, i have used the hp unlocker tool and it created a unlock file but password has not been removed, can anyone help please.
                  https://www.badcaps.net/forum/showthread.php?t=72246
                    I used the HP unlock tool with 840 G6 8gen but no success
                    Any help pls ?
                      Because G6 is supported by rcunlocker, not this old tool. Use rcunlocker on your original EC dump.
                        Thank you but when i drop the 32mb file on rcunlocker i have an error
                          i found it it was in the back of the motherborad
                            Thank you
                            Mohammed Mohan
                              Thank u it working
                                HP EliteBook 745 G4 TRAVOLTA-6050A2834601 MB A01
                                i have issue with Power-on Authentification
                                here are my original main and EC bios bin, please anyone can clear for me
                                THX
                                  THX
                                  SOLVED
                                  i attach the working bios clean
                                    thank you very much .
                                      Thank You and more power
                                        Hi.
                                        i have 2 zbook 17 g4, i read the bios and unlocked it with unlocker. the laptops turn on but the fans spin 100% and the screen is black. As i was reading the forum i saw in one of the posts that updating the bios solved the problem, can someone do this for me? thanks in advance
                                          Hey guys can somebody explain to me why is the password still there even after RCUnlocking the 128 chip.. It's an HP 745 G6
