#201 |
City & State: Newnan
My Country: United States
![]() So not booting with copied w/changed sn. Is this result of me area not cleared? If so, please tell me that process. Thank you.
#202 |
![]() After copying another similar machine BIOS, I was wrong about not booting-simply had forgotten to replace memory. Even though I searched/replaced serial number, the donor BIOS machine serial number showed up. Additionally, the ME Firmware was not present. When I tried to run the batch file to write ME Firmware, it would fail. I fiddled with batch file to bypass checks with no sucess and I also ran update exe from cmd. Maybe with more time, could get this to take but I went back to the PW removed BIOS provided to me by @peste. Same as before:
"Have tried again the L25 BIOS update, same behaviour with stopping at update screen. These two updates worked: -Embedded Controller V3.00L13 to V3.00L14 -ME Firmware 11.8.60.3561 to 11.8.82.3838 Also, I notice under Panasonic PC Setting Utility / PC Information Viewer / Setup: ... BIOS V3.00L17 BIOS Configuration 0014-FFFF-00D5 Sample ID ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ < Do not see this line on similar machine Embedded Controller V3.00L14 ..." I'd appreciate any suggestions to correct the L25 update issue. Thanks again. |
#203 |
City & State: vietnam
My Country: ho chi minh
![]() i have a cf-54 i5 7300 with password in bios
can someone help me to remove password? thanks alot Attachment 288815 Last edited by SMDFlea; 04-03-2023 at 09:34 AM.. |
#204 | |
City & State: CAMPINA
My Country: ROMANIA
![]() Quote:
#205 |
#206 |
#207 |
City & State: Sofia
My Country: Bulgaria
![]() Hello,
I have a CF-54 and I don't know what information is required to reset the BIOS password? |
#208 |
City & State: kuala lampur
My Country: pakistan
![]() need to remove password ori file is attached
#209 |
My Country: ROMANIA
![]() Last edited by SMDFlea; 04-03-2023 at 09:34 AM.. |
#210 |
#211 |
City & State: Hannover
My Country: Deutschland
![]() Hello Guys,
i have a Toughbook CF-54 Model No. CF54CY004EG and Serial No. 6ATCa41920.. After a "load setup defaults" in bios, the toughbook surprises me with a bios password, which was not used before. Unfortunately the setup defaults switch my boot devices, so I can boot only via USB Stick. For this reason I can dump bios via freedos programm only. I tried some afudos vesions without success. Flashrom asks for the right Flash-Chip, have no clue how to find this out. I read this hole thread and the "how to" thead carefully. My question is: How can i dump the bios? Thank you! Greets. Sebi I read all the bios stuff ca |
#212 |
City & State: Gujranwala
My Country: Pakistan
![]() Hello
please help me to unlock CF54 bios password Thanks Last edited by SMDFlea; 04-03-2023 at 09:34 AM.. |
#213 |
VIP Moderator
City & State: Sofia
My Country: Bulgaria 🇧🇬
I'm a: Hobbyist Tech
![]() Did you tried already to remove the password, or it was someone else's job?
---------------------------------------------------------------------------------------------------------------------------------------------------------- Due to a lack of donations needed for monthly server fees and maintenance costs, and possible closure of Bios Requests all donations are welcome, see the donate button below, at the bottom of the page, or >>>>> click on this link to donate via PayPal. <<<<< Every donation made will go towards server fees and maintenance costs. ---------------------------------------------------------------------------------------------------------------------------------------------------------- Doctrina est fructus dulcis, radicis amarae.
#214 |
![]() its the old one. Thanks its done .
#215 |
VIP Moderator
City & State: Sofia
#216 |
![]() ![]() laptop same. New dump file only |
#217 |
City & State: tokyo
My Country: japan
![]() I have a CF-54 with a password in the BIOS.
Can someone help me remove the password? Thank you very much |
#218 |
City & State: kur
My Country: rus
![]() hi dear, please help me pass dekete
#219 |
City & State: Whatever
My Country: Whereever
#220 |
City & State: Zacatecas, Zacatecas.
My Country: Mexico
Line Voltage: 120VAC 60Hz
![]() @droopy234
Seems like you used a software utility to read the BIOS, so file is empty (FFh) from 0h to A00000h (first 10MB), in this address range is where the Descriptor, GbE and ME Regions are located. So basically your file is just a dump of the BIOS Region. We use a software utility to read a BIOS when the password can be recovered from it, for a CF-54 you need a FULL bios backup obtained using a SPI programmer. |
Thread Tools | |
Display Modes | |
