acer aspire E1-572g V5WE2 LA-9531P bios bin
    hello, blue led turns on the fan 3seconds, black screen both with and without ram, tried reflow gpu without solving, I thought it may be the bios corrupt, I am looking for a bin file for this card, the SNID is: 41704155334, thanks
    ps. chip bios: EON , EN25Q64
    Re: acer aspire E1-572g V5WE2 LA-9531P bios bin
    Never start with reflow gpu , maybe you make the situation worst !
    Try this , if not working post your old dump (don't forget to save your old dump )
    https://www.alisaler.com/acer-e1-572...bios-bin-file/
      hello, yes of course, but I warmed up just to see if it depends on the gpu, I have already tried this file but it does not work, the notebook turns on for 3 seconds then goes off several times always black screen, I noticed that when I turn it off it does not turns off immediately but you have to keep the button pressed for 5 sec, as if you don't see the ram, usually with this situation the fault was almost always the fault of the gpu
        how do I post the original saved dump?
          Easy , in the windows of reply , button go advanced and you find : Attatchements..upload your file than exit than submit reply
            I correct the name bios chip: EN25QH64
              Try and give feedback
                I tried but it doesn't work, it turns on with a black screen
                  try this one
                    congratulations, with this file the screen turns on
                    thank you so much
                      thank you
                        I'm having an identical problem. Tried the alisaler bin file using a CH341A. EPROM took the bin but still black screen. Happened across this thread and going to try the 2.17 ME CLEAN bin tomorrow and report back. So glad I found this site.
                          Originally posted by SMDFlea View Post
                          try this one
                          Thanks for the file it saved me too!
                            try this one
                            thank you
                              thank for this bios dump. it works!
                                thank you
                                  thank you
                                    thanks bro
                                      thank you
                                        many Thanks Sir works perfectly
