Friends, many times when you solder a new ITe ec and try to program it with svod(with correct pinout downloaded), we get a message "ITE series not detected". This is very common issue while replacing Lenovo G50 series with NM-A311/271/282 etc motherboards.
Solution:
You just need to trigger the motherboard once(means press power switch once) after connecting with svod and after doing setup,connecting adaper and gnd. In otherwords you need to press power switch once after doing all whatever is required to program ec.
Learnt it the hard way after replacing 3 IT8586E ec on Lenovo NM-A311 mb and getting same error on svod-ITE series not detected.
Hope it helps someone in the forum.
Solution:
