Vizio E60-E3 No power, No standby light
    Hello all, i have a vizio that will not power on at all.
    PS board part number is 09-60CAP0D0-00.
    PS output pins read
    1. VSNS __0V
    2-5. LED-OUT__0V
    6-10. GND__ohmed 0.2 or less
    11. +16V__16.3VDC
    12. AC-DET__1.8VDC
    13. PS-ON 0V
    14.+16VS__16.4VDC
    15.+16VS__16.3VDC
    I was told that it was struck by lightening. Here's a pic of the power supply.
    Re: Vizio E60-E3 No power, No standby light
    probably a bad main main IC on the main board.
      I have ordered a main board & I'm waiting for it to be delivered. In the mean time is there a way for me to test the IC? Is ac det considered to be the standby voltage? It’s reading 1.8. Pressing the power button has no affect on the voltage reading.
        The ac detect is not the StdBy voltage. With the ac applied, what voltage do you have across e-cap C2?
          PSon is generated on the main board. So if you don’t get any PSon, the PSU won’t power up fully either.
            That means your Man Bd. is shot.
              163.4 V on c2.
                Red lead on the +ve and Black lead on the -ve??
                  Yes, voltage across the main cap legs is 163.4 VDC
                    I've got the same model TV with the same basic problem:
                    - No power, no standby/power LED, power button does nothing
                    - Same readings on the power board pins
                    - EXCEPT Pin 12 (AC-DET) is ~3.5V when the board is powered
                    - AND I've confirmed there's no change on Pin 13 (PS-ON) when the power button is pressed
                    The TV was being thrown away because "it just stopped working".
                    Does this sound like the same problem as the OP or should I start a new post? Does the difference in Pin 12 voltage help with troubleshooting either of our TV's issues?
                      So you do not have any +16VS?
                        As I said, I have the same readings on the power board as the original poster except Pin 12. All +16v pins are fine (11, 14 & 15).
                          GASTUNTMAN
                          i have the same model and the same problem you had with that vizio
                          E60-E3.
                          what was the repair. i also ordered the main. be here soon.
                          hope to get some feed back. thanks.
                            seeing that the op never posted back after relaying that he was getting a replacement mainboard, I'm going to guess that the new mainboard fixed it. All we can do IS guess when there's no followup. But I guess some people are just TOO important to be bothered with it.
                              thanks again for a reply.
                              i had ordered a main, doing the same thing. main not producing ps-on
                              voltage. i will assume that the main i got is also defective. being that
                              these board suffer the processor not doing its job. i'm always open to
                              repair input and always learning. more feed back. thanks.
                                Originally posted by GAStuntman View Post
                                I have ordered a main board & I'm waiting for it to be delivered. In the mean time is there a way for me to test the IC? Is ac det considered to be the standby voltage? It's reading 1.8. Pressing the power button has no affect on the voltage reading.
                                I think there is a way to test whether the main IC is bad, by checking main bios. Check the VCC pin 8 is there a 3v, if yes you can then check pin 2 for the communication between the main chip and the bios.
                                  simple me, but im trying.
                                  need some kind of run down on how this unit works. ac cord connected gives me 160plus
                                  volts on c2. 16v on 3 pins and 3.9v on ac_det. question. is this normal procedure when
                                  ac cord is connected. how is the standby produce. I have voltages on my on swisches.
                                  they go down when power on sw is press and same with remote. yet i get no ps-on
                                  voltage. nothing out to the lamps. i jump ps-on and got 16 plus volts on the lamp connector. a run down on whats happening will help alot. thanks.
                                    https://www.youtube.com/watch?v=vJn_...StuffwithT%26A
                                      Mr badcaps veteran
                                      you hit the nail on the head. main which i bought was defective. i have sent it back.
                                      this unit works just like every other unit. main not able to produce ps_on.
                                      bad main. thanks
                                        got the main and tv looks good.
                                        thing is that i have used 3 different remotes and menu never comes up.
