Can someone please tell me the value of the resistor pictured? Can you tell me the exact resistor I need to order to replace it? Thanks in advance!
Need help with resistor value please
Re: Need help with resistor value please
Why do you want to replace it? What are you trying to fix?
It looks like RED-RED-SILVER = 0.22 Ohms.
Gold = 5% Tol.
Green = Temp Co. NA.
https://www.allaboutcircuits.com/too...de-calculator/Last edited by budm; 08-07-2020, 04:56 PM.Never stop learning
Hey budm, I am working on a Vizio M65-C1 and when I got it it had no power. I watch a Youtube video of someone that has the same problem with the same model TV. I replaced a resistor and diode that he showed on the power supply. When I powered up the TV it came on for a second and blew the same resistor again. It's a SMD resistor mounted on the bottom of the board. So I got to checking components in the area of the SMD resistor and found that the resistor, like the one pictured, has no resistance whatsoever. So I am thinking it is bad. I am posting another picture of the actual resistor. It seems to have a small bulge on the side of it.
1.2 ohm
brown 2 red 2 silver .1Last edited by chrismurphy; 08-08-2020, 06:08 AM.
Originally posted by JunkmanJimbo View PostHey budm, I am working on a Vizio M65-C1 and when I got it it had no power. I watch a Youtube video of someone that has the same problem with the same model TV. I replaced a resistor and diode that he showed on the power supply. When I powered up the TV it came on for a second and blew the same resistor again. It's a SMD resistor mounted on the bottom of the board. So I got to checking components in the area of the SMD resistor and found that the resistor, like the one pictured, has no resistance whatsoever. So I am thinking it is bad. I am posting another picture of the actual resistor. It seems to have a small bulge on the side of it.
Show us good clear straight shots of the whole top and bottom side of the board.Never stop learning
Originally posted by JunkmanJimbo View PostI replaced diode D9103 and resistor R9114 but resistor R9114 keeps blowing.
If you look at the bottom side of the board you will see the followings:
1) R9114 (protection resistor), D9103, C9103 are for making running DC from AUX winding of Standby power supply transformer T9101 to run the Standby SMPS IC9101, that DC is also fed to switched Transistor Q9102 to supply the switched VCC to run the PFC IC9801, 12V/24V SMPS IC9201
2) What is the original D9103 P/N number? What did you replace with?
3) Was original R9114 blown? What was the printed on the body? What resistance value did you replace it with? Does it blow up when you first apply the power to TV or AFTER TV is turned on?
4) R9101 (0.12 Ohms) is the current sensing resistor connected between Source pin of MOSFET Q9101 (for driving Standby power transformer T9101) and Hot side Ground.
So in the beginning before you work on the power supply board, you were not getting ANY DCV from the power supply board connector to the main board?
Please give the link to the Video that you use to try to fix this board.Last edited by budm; 08-08-2020, 05:18 PM.Never stop learning
Originally posted by budm View PostIs this your board? https://www.shopjimmy.com/vizio-adtv...ly-for-m65-c1/
Yes this is my board.
Original 621-PR1007G-T
Replaced with 1N4007FFG
The original R9114 was blown (had a hole in the center of it). I replaced it with the same part number and resistance value. When I first plugged the TV in after replacing the resistor and diode, the led light on the main board was solid red, instead of flashing, so I thought I had it fixed. When I turned the TV on, the V logo came up on the screen and I then I heard a pop and that's when the same resistor blew again.
I didn't actually check that budm. I just replaced what I saw in the video because I was having the same symptoms.
2) What is the actual printing on the diode D9103?
"Original 621-PR1007G-T" 621-xxxxx is Mouser P/N, it is Fast recovery diode.
"Replaced with 1N4007FFG" that is standard recovery diode not Fast recovery diode used in switching power supply.
3) So what is printed on the R9114, what is the resistance value?
From that link, the blown up in the picture one looks like 1R0 (1 Ohm).
When TV is turned on, more current will flow through that resistor due to current drawn from PFC and SMPS circuit.
You need to check the resistance between GND and the VCC pin pf the PFC IC9801 and the 12V/24V SMPS IC9201 to see if they show low Ohms value or not.Last edited by budm; 08-09-2020, 03:20 PM.Never stop learning
Originally posted by Diah View Postam sure as i wrote before if its not F or FB then will be 1R
FB = Ferrite bead INDUCTOR used for blocking high frequency, not for over current protection, it can be as simple as piece of wire through Ferrite bead.Last edited by budm; 08-09-2020, 04:47 PM.Never stop learning
You can learn a lot about diode here at Toshiba website
https://toshiba.semicon-storage.com/...2/chap2-4.html
http://www.learningaboutelectronics....very-diode.php
https://www.shindengen.com/products/...iodes/frd.html
So what is the P/N as printed on the original diode you remove?
https://www.mouser.com/ProductDetail...4DF5Ceiw%3D%3D
https://www.mouser.com/ProductDetail...cEos2YIT4pE%3DLast edited by budm; 08-09-2020, 06:02 PM.Never stop learning
Originally posted by Diah View Post0.12 Ohms make no sense to put in PWB design .. they will use F or FB or 1R to protect certain parts
You can clearly see as to what R9101(0.12 Ohms) is used for, very simple topology: Low side current sensing.Last edited by budm; 08-09-2020, 05:47 PM.Never stop learning
Dear budm, i don't know why you are now defending bad design of HOT AREA MB. in simple words if it was successful design then never being popular fault at HOT. many other MB working for years with out issue at HOT area unless there are strike by AC.
BTW R9114 1R
Originally posted by Diah View PostDear budm, i don't know why you are now defending bad design of HOT AREA MB. in simple words if it was successful design then never being popular fault at HOT. many other MB working for years with out issue at HOT area unless there are strike by AC.
BTW R9114 1R
Do you understand what the current sensing is about?
Show me the circuits.
Is Unitrode using Rsense bad design? May be you know more about power supply design than UNTRODE, POWER iNTEGARTION, FAIRCHILD, Ti, etc.
The topology has been in use for decades.
You should read up on spec sheet and application notes of SMPS sometime then you will understand.
You can ask anybody here at BC that deals with power supplies and see if they think it is bad design to have current sensing circuits.
Any one out there want to answer this beside me?
https://cdn.badcaps-static.com/pdfs/...b1b3743513.pdf
BTW, why are you referring to 'HOT AREA MB'?
You do know what R9114 is located and know what it is used for, correct?Last edited by budm; 08-10-2020, 01:26 AM.Never stop learning
Originally posted by budm View PostWhat bad design are you talking about? I use resistor as current sensing in 100's of power products I design and as so many power supplies design out there in the world.
its late to you.. don't argue before you go to bed.
good night.
