Microsoft Surface Pro 7 NEED BIOS. HELP!
    Re: Microsoft Surface Pro 7 NEED BIOS. HELP!
    Originally posted by AAAC View Post
    @magneh
    I've taken PESTE bios (post #8) and complemented it with your bios (bkp.zip, post #29), invalidated "SetOEMStrings" UEFI variable... but seen other Dfcixxxx UEFI variables too.
    If this bios works it will be your starting point, then you can take care of the MDM/DFCI.
    @AAAC
    Thank you, really appreciated you took the time.
    Gonna test in a bit and let you know.
      @magneh
      Thanks again AAAC.
      Device booted with your dump!
      I can see now the touch firmware version also, but touch still does not work.
      Device was brought to me already disassembled, even if screen not broken, touch could be defective itself.
      Regarding the MDM/DFCI , I suppose I should try to update firmware in windows to see if everything is good?
      Ive seen that bitlocker is active, so I couldnt get to login screen
      Thanks again for your help!
      Saludos a Mexico
        @magneh
        Try to check Touch connector, ripped flat cable, etc.
        Have you tried to use your own "bkp.zip" (post #29) file? to me seems to have the correct structure, have patched the SetOEMString UEFI variable too on this one.
        (The other "original.zip" file from post #29 is damaged)
          @magneh
          Hello AAAC!
          Thanks for checking that bkp.zip dump.
          Ive just tried it, and it works!
          Same touch firmware version, but now works perfectly.
          Thanks for helping me with this one!
          Saludos para zapatecas!
          Gracias amigo.
            @magneh
            Hi. Can you edit bios for pro 7 that only shows logo.Thanks.
              i have a surface pro 7 touch not work, can you fix help me!
                Hi
                I have a surface pro 7 Bios locked, can you please help to remove the password?
                  Originally posted by fthgyj View Post
                  Hi
                  the posted bios is corrupt ... what programmer are you using ??
                    I am using Universal Bios Backup Toolkit 2.0
                    Just tried again, hopefully it works
                      @fthgyj
                      The utility "Universal Bios Backup Toolkit 2.0" only works in those models when the password can be recovered, the utility only READ bios region (a partial bios chip dump, missing: ME Region, Descriptor Region and other), from that bios reading/dump the password is recovered.
                      In your case what you need is a bios chip programmer to obtain a FULL bios chip backup, then this backup can be patched and programmed back to bios chip.
                      If we could just build a kind of (SHA256) "rainbow table" with password hashes, then it will be a matter of looking up for your hash in that table and we would recover the actual password.
                        post the original bios, even if it is corrupt.
                        Hi Every one My surface pro 1866 shows windows logo on and off. i think bad bios can some one fix the old bios .
                          Hi, My surface pro 1866 shows windows logo and turned off I reprogramed few bios available on internet but no luck . is it possible to fix my old bios backup?
                          I attached my old bios back up .
                          thank you
                          Last edited by SMDFlea; 06-29-2022, 10:22 PM. Reason: there is no need to post the same bios again... just bump the thread !
                            Re: MS Surface no touchscreen after cleaning ME Firmware **FIX**
                            hi.
                            i have a surface pro 7 bootloop in logo.
                            please help me fix this. thanks.
                              Originally posted by LiveOnMercury View Post
                              hi.
                              try..
                                try..
                                not working. thanks peste
                                it bootloop again
                                  Hi everyone.
                                  I have a surface pro 7 with bios password. I have tried every single bios dump here but my surface pro will only show windows logo for 3 seconds and go off again. but the original locked bios boots fine. This is my backup below may be anyone could help remove paasword or do some kind of magic. thanks in advance.
                                    @Tjaytony
                                    I've seen something similar before, it may be due to the SATA hard drive configuration in Setup/BIOS, it may be either "IDE Compatible mode", "AHCI mode" or other like "RAID mode" (have seen only the first two). So changing the SATA hdd mode may make a difference, but it's always better to work with the Original BIOS file.
                                    Give a try to your Original patched BIOS file.
                                      Tnx I'll try it this noon.
                                        Hi. i have the same device. i flashed a working bios, but i have no touch firmware. can anyone help me remove the password from original file?
                                          @maraketh
                                          Hi, this is your Original BIOS, patched to remove the password(s).
