Hi guys! Set is completely dead! Checked the psu and a blue ceramic cap had exploded also the fuse was dead so I've replaced both of them with the correct value replacements but it's still dead nothing voltages from psu to mainboard are all 0! I haven't got a multimeter at the minute though ( cheap Chinese one fell apart so ordered a better one) does anyone know what are the main causes of a completely dead set are? I've read alot about lg sets with faulty mainboards! Cheers!
32lm3400 dead no standby
Re: 32lm3400 dead no standby
You have two power supply sections:
1) The SMPS IC 501 is for the always on 3.5V standby power supply section.
2) That C102 is the snubber cap for the MOSFET Q101 which is for the switched power supply that will only come on when PWR-ON control signal is present.
Right you do not have Standby power to run the main board so that will be the section you need to test first.
What DCV do you have when measured right between the two legs of the main filter cap C110?Never stop learning
Connect your meter set to AC volts and measure the voltage at the two black arrows "~". One meter lead on each point.
Then measure the DC voltage at the two red arrows. Red meter lead on "+" and black meter lead on "-".
Don't let the probes slip since this is the Live (HOT) side of the circuit board.Willing to help but I'm no expert.
Originally posted by dick_barton View PostConnect your meter set to AC volts and measure the voltage at the two black arrows "~". One meter lead on each point.
Verify that the replacement fuse is good, also verify that you do have 230VAC between the two pins of the incoming AC connector on that power supply board.Never stop learning
Originally posted by budm View PostVerify that the replacement fuse is good, also verify that you do have 230VAC between the two pins of the incoming AC connector on that power supply board.
https://www.youtube.com/watch?v=HuWly36NyEE <---- thats how i test fuses!
the fuse now appears to be bad if im testing it right lo but was 100% good before i soldered it in! and i know ive got the correct replacement 100%!
Originally posted by dick_barton View PostThere appears to be some marks on the circuit board alongside C102 which I would check is not damaged. Also check the mosfet alongside it Q10x? is not short circuited.
Originally posted by jonny78 View Posthi ive already replaced c102 as it had blown.. will check the mosfet shortly! ive now only got 1 replacement fuse left though as they are fine but when i solder them in and turn the power on they seem to be blowing
You need to check the mosfet since the snubber capacitor was damaged and so is probably also damaged.
Hopefully you can find the fault. With the set disconnected from the mains and just using your multimeter set to ohms check the mosfet.Willing to help but I'm no expert.
You need to verify that R114 is also OK or not, it should be <1 Ohm + your meter probes resistance.
Hopefully that IC101 is not damaged when that MOSFET shorted out otherwise you will damage your new MOSFET.Last edited by budm; 07-10-2018, 01:47 PM.Never stop learning
