Re: Help me understand this schematic Harman&Kardon tape deck (TD470)
Ok, I kind of understand this part. It looks like the MONITOR signal (if traced correctly this line) toggles this relay to forward the out signal from the IC503 out to the op amps in IC504A, which basically are the end stages before LINE OUT sockets. I will have to test for audio signal at the relay pins, and at the in and out of the op-amps in IC504A. There's also a transistor right before the LINEOUT connector that may have to be checked.
Do this sound correct?
Thank you!
Originally posted by budwich
View Post
Thank you!
