DSP firmware error on a Pioneer LX86
    Please help me who went through the DSP firmware error on a Pioneer LX86.
    Mine now shows 1-204084 *** 160 .
    Every time I try to update the firmware via USB, the message Update Error 1 appears at 45%
    Thanks and sorry if I posted where I shouldn't .
    Re: DSP firmware error on a Pioneer LX86
    do a factory default / reset and try again updating...
      Replace the associated eeprom. It will likely need programming before installing so you'll have to search the net for the .bin file.
        Morning, thank you for reply. The DTS chip need to be replaced as well? I read on different forums and they said the eeprom is stored on DTS chips.
        I did a factory reset, I check what error appear in the service menu...the firmware is damadge.
          Yeah, sounds like the eeprom is screwed.
            Hi. Did you get Eeprom dump for those DSP?
              Here is a working dump from LX56 which comes with the same dsp and spi chip.
