Not a repair, only a purchase advice ask for
    Hi, briefly for a purchase advice i would like to know from experts if recent LG still suffers processor soldering problem, like almost every LG led tv i know. Thanks.
    Re: Not a repair, only a purchase advice ask for
    Some incomplete info I know of LG TVs.
    Bag BGA or processor:
    LG series from 2009
    LD some models
    LV
    LM
    UF higher end models
    Horrible panel:
    F
    J
    H
    Bad Backlights:
    F
    J
    H
    The whole F, J and H series are a fiasco, backlight that turns blue over time, and panel dies like flies, develops horizontal lines or flickering.
    Seems that from UM series forward LGs have been solid, at least compared to Samsung, their NU series have terrible backlights. RU, TU and expensive QLEDs have been having panel problems. I haven't seen any LG UM models or newer with any fault for sale around here.
    Easy to figure out when you search the motherboard for a select model and check the price, usually if it has bad BGA there will be listings offering to "repair" the board, and a working one will cost at least 70% of what the TV is worth.
      thanks, which of them are now on the market?
        being sold new?
        LB 2014 < backlight problems
        UJ 2015
        UH 2016
        UJ 2017
        UK 2018
        UM 2019
        UN 2020
        UP 2021, being produced and sold for now.
        For Nanocell I'll use a single model as example:
        SJ8500 2017
        SK8000 2018
        SM8600 2019
        NANO85 2020 - NANO86 in some countries
        NANO85 2021
        The "U" is for ultra HD (4k), for 1080p/768p LG uses "L" prefix, like LF or LJ
        Bottom tier LED TVs have reached stagnation, there's nothing new since 2017, same peak brightness, panel types vary from manufacturer, lg 55 inch is IPS or ADS, they're similar, some 60 inch models uses VA.
        Even high tier, most of them are 4k 120Hz, the only difference between them is having a higher peak brightness with mini-led or 8k panel, which has no use right now.
