Thank you to the guys at HEGE supporting Badcaps HEGE HEGE DEX Chart
windows 7
    windows 7
    fuck windows - i dont know how you put up with it!
    i just wasted a whole fucking day trying to install ,NET 4,8 for somebody.
    it wouldnt install,
    eventually i found out it was failing the security check because windowz needs it's certificates updating.
    then i spend hours trying to find certmgr.exe to install without downloading 35 fucking gigs of visual studio sdk!!!!
    still not found it or fixed this shit o.s.!!
    Re: windows 7
    Use WSUS. One if it's first actions is to update root certificates
      Re: windows 7
      Was just going to suggest that.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        Re: windows 7
        and how will that work on an o.s. with hacked registration?
          Re: windows 7
          If you used the DAZ loader, it'll be fine.
          Team : 49813
          Join in!!
          Team Stats
            Re: windows 7
            looked at it,
            no go - the security certs i need are not part of any update - they are post EOL for win7
            thats why i need the command-line tool - i can add the certs manually without a cab file or msi wrapper
            or i just dont waste any more time on this crap.
              Re: windows 7
              With all your bitching and trying to blame Microsoft for your ignorance I can't tell if you still want it or you've given up.
              Maybe just ask next time and save yourself a load of frustration.
                Re: windows 7
                That's as big as a game! At least roughly the same ballpark as PC Halo MCC! Almost as big as GTA V! LOL!
                The rate we're going, I wouldn't be surprised if a 1 TB HDD, becomes the minimum requirement soon, LOL!
                Definitely going to be true even more shortly, if not already, for most SSDs, because a 500 GB SSD could have too many writes to cells. They are already starting to feel like a 240 GB SSD already here, LOL!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                16 GB AData XPG Spectrix D41
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                  Re: windows 7
                  Just follow the first two steps of the "Prerequisite" section in any of the latest MS KB articles like this one: https://support.microsoft.com/en-us/...5-33c7f32fe7f4
                  I.e. this is what you need: KB4490628 & KB4474419
                  Here is a more in-depth article on the subject: https://support.microsoft.com/en-us/...0-69a4cde8e64f
                    Re: windows 7
                    Yes, you need root cert updates, even if you disable windows update. And you could have downloaded the offline installer too.
                    Here is the authroot.stl http://ctldl.windowsupdate.com/msdow...uthrootstl.cab
                    Uncab, install and enjoy. Also, you need to download the SHA2 Update for Windows7.
                    And for some newer drivers - Kernel mode driver framework.
                    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                      Re: windows 7
                      i fixed it already with an unlisted KB that breaks auto updates - fine by me!
                      (KB3004394)
                      and a certs update afterwards from an STL.
                      still a shit o.s. and terrible documentation from it's spreaders.
                      so now it's owner can install dot-net 4.8 and go break something else i suppose.
                        Re: windows 7
                        why did they need 4.8 to begin with?
                          Re: windows 7
                          some software related to apple phones - another headache i try to avoid!
                            Re: windows 7
                            i fixed it already with an unlisted KB that breaks auto updates - fine by me!(KB3004394) and a certs update afterwards from an STL.
                            still a shit o.s. and terrible documentation from it's spreaders. so now it's owner can install dot-net 4.8 and go break something else i suppose.
                            Windows7 is actually not a shitty OS, contrary to the next versions. And there is plenty of information and documentation about it. Not that I am a big fan of .NET framework, but it eases programmers work tremendously. If no standard libraries are used or exist, everybody will have to reimplement the wheel.
                            BTW, certs are updated independently and are not part of the usual Windows Update, but because of the SHA2 if you have disabled automatic updates and haven't installed SHA2 update, cert updates can fail too. Or not updating anything for a long time...and the MS cert installed on the machine itself expires...and then it refuses to install them because of invalid cert chain.
                              Re: windows 7
                              It started out that way.....but after SP1 came out, I never looked back. As a matter of fact I'm still using it with extended updates.
                              Team : 49813
                              Join in!!
                              Team Stats
                                Re: windows 7
                                Unfortunately, the 7 WU is infamous for error code 0x80080005 with what I believed I traced to certain early-2010s' major updates, when not installed one at a time with a reboot after each!
                                IIRC, I traced that to updates that are from pre-2012, if not solely certain updates from 2011.
                                  Re: windows 7
                                  This is why I use WSUS update for all windows 7 updates. Keep the client folder on my NAS
                                    Re: windows 7
                                    And just to piss off more windows 7 users, If you are using Microsoft edge, as of a couple days ago, you can no longer have the home page of your choice (IE Google) It now starts up with the "New Tab Microsoft" and you need to click on the Home icon to get your original home page
                                      Re: windows 7
                                      Never seen it....even on client machines.
                                      Anyone voluntarily 'uses' Edge? It's not installed on any of my 7 or S2K12 systems. Funny, for as much good software M$ has written they have never had a web browser that's been worth a shit...
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        Re: windows 7
                                        Well, that bug bit me a lot on fresh installs! At least for certain updates from 2011, IIRC, I apparently have to install them "pseudo-NT4-style" as a workaround!
                                        (chronological order)
                                        This is why I don't recommend the WU page/menu for 7 anymore!
                                        IIRC, it bit me on Core 2 systems, so it couldn't have been bad caps, IIRC, also happened on my new-at-the-time PC! At least as late as 2013 as well, IIRC, when doing a fresh install for my Core 2 Duo system.
