would using such an old drive for swap be a stupid idea?
12gb quantum bigfoot ts as swap
Follow the white rabbit.Tags: None
Re: 12gb quantum bigfoot ts as swap
dedicated I/OThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
You do realize that random access time, not sequential access speed, is what matters for swap, right?
On a related note, why haven't any companies released 5.25" full-height drives for a long time? They would sure make people that need a lot of storage but not a lot of speed very happy. I could see 20TB being stored on one of those...
so i should use my old 10gb IDE laptop drive then
and since im on the topic, time to see windows vista run from one of them quantum bigfoots
thanks for the helpLast edited by goontron; 05-25-2013, 01:48 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
if you have enough ram, disable swapCap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by Uranium-235 View Postif you have enough ram, disable swapThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
linux creates no seperate hibernate file outside of the swap partition?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by cheapie View PostI think Windows is the only OS that uses hibernation files.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
I havent seen a working bigfoot in over a decade....even when they worked, they were slow as bejeebus!<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Originally posted by Topcat View PostI havent seen a working bigfoot in over a decade....even when they worked, they were slow as bejeebus!Last edited by goontron; 05-26-2013, 11:04 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Last edited by goontron; 05-27-2013, 12:18 AM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
using flash is a possibility, but since there is soooo much random writing, the write cycles would get used up waaay to fast. Better get an extended warranty on it
in Win7, I had no swap file, 12GB of ram. Thing ran beautifully. I can say that is one of my fav advantages over the winNT5 kernelCap Datasheet Depot: http://www.paullinebarger.net/DS/
i have 2gb ram and the CF card *had* an extended warranty but it an old card and it up.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
not a CF card, that isn't fast enough flash memory, need an SSDCap Datasheet Depot: http://www.paullinebarger.net/DS/
