Does anyone here use debug cards?
    Just wondering, do these cards work? To make diagnostics easier.
    http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
    Re: Does anyone here use debug cards?
    Port 80 POST cards work very well, particularly for the low price. At a minimum they tell you if your board has life when it won't show video. After a few screwups you start picking up on what some of the codes mean so you can instafix. C1, that memory must not be compatible. If it's counting the low numbers then I probably forgot to switch the KVM.
    I have several but the only one I actively use is a card by QiGuan.
    sig files are for morons
      I'm assuming you are talking about desktops? How about using one for laptop motherboards?
        There is many laptop motherboards, that don't work with debug cards due to compatibility issues. (LPC bus is not wiring in some of them)
          I can say they wont work with most of motherboards, codes differs due to motherboard and BIOS models, but still worth to buy.
            there are 4in1 cards for laptops. So they fit every laptop mobo. I dont use it for the codes, but it is good to see clock and reset signals. and of course the codes work depending your experience with the card.
              Which one did you buy?
