12gb quantum bigfoot ts as swap
    would using such an old drive for swap be a stupid idea?
    Follow the white rabbit.
    Re: 12gb quantum bigfoot ts as swap
    It would of course work, but why not just make a swap partition on your main hard drive ?
    I don't see a point in using such an old (and big, 5.25) HDD just for swap.
      dedicated I/O
        You do realize that random access time, not sequential access speed, is what matters for swap, right?
        On a related note, why haven't any companies released 5.25" full-height drives for a long time? They would sure make people that need a lot of storage but not a lot of speed very happy. I could see 20TB being stored on one of those...
          so i should use my old 10gb IDE laptop drive then
          and since im on the topic, time to see windows vista run from one of them quantum bigfoots
          thanks for the help
            if you have enough ram, disable swap
              if i do that it cannot hibernate tho
                And why is that bad?
                  linux creates no seperate hibernate file outside of the swap partition?
                    I think Windows is the only OS that uses hibernation files.
                      I see that as another +1 for windows
                        If you are not using a computer, turn it off! I see no reason for hibernation, and always disable it. I have Linux on a SSD, and it is faster in booting than the Windows laptop at work is just coming out of hibernation.
                          a bigfoot that still works?
                          even if true its slow by todays standards.
                            I havent seen a working bigfoot in over a decade....even when they worked, they were slow as bejeebus!
                            <--- Badcaps.net Founder
                            Badcaps.net Services:
                            Motherboard Repair Services
                            http://folding.stanford.edu/
                            Team : 49813
                            Join in!!
                            Team Stats
                              one of the last! it came from the jeffco courthouse in colorado and its barely used so no bad sectors, no bad bearings, spins up fine to! had windows mistake edition on it ,so no wonder it never got used and it also benchmarks fine.
                                A 12GB flash drive for swap will be better, faster, and cheaper.
                                sig files are for morons
                                  i use this for swap right now, i just wanted to find a use for this old quantum beast.
                                    using flash is a possibility, but since there is soooo much random writing, the write cycles would get used up waaay to fast. Better get an extended warranty on it
                                    in Win7, I had no swap file, 12GB of ram. Thing ran beautifully. I can say that is one of my fav advantages over the winNT5 kernel
                                      i have 2gb ram and the CF card *had* an extended warranty but it an old card and it up.
                                        not a CF card, that isn't fast enough flash memory, need an SSD
