Mixing logic families
  • vsmGuy
    • Jul 2006
    • 28
    Guys,
    Is it advisable to interface LS family digital logic parts with a uC like AT89C52 or PIC, or should I use HC parts instead ?
    For example, would it be a good idea to connect a 74LS74 to the above mentioned uC pins or would it be better to connect a 74HC74 ?
    An anecdotes and ideas/suggestions ?
  • shadow
    • Feb 2007
    • 732
    Re: Mixing logic families
    I have not looked at those chips yet, however mixing logic families can give you alot of problems. The chips that you use have to be compatible with each other otherwise it is a real nightmare getting it to work the way you would want it. The easiest way of making sure that chips are compatible is to use chips from the same series from the same manufacturer if possible. That way you do not need to look at data sheets and deduce whether your chips will work with each other.
    Having said this, the main aspects that you will be interested in the datasheet is the minimum voltage recognised as a 'high' and the maximum voltage recognised as a 'low'.
    • gg1978
      • Dec 2004
      • 431
      what kind of voltage do you have on the output pins of the PIC or Atmel uC?? If they're 3.3V, i wouldn't use a LS series myself, but at 5V it should be fine. Technically speaking regular TTL "should" be OK at 3.3V, as logic high is anything between 2.0 and 5.0x V..
      HC should work either way, as long as you're within voltage specs.. Also LVTTL is an option if your chip is 3.3V or less.. Not sure how low LVTTL can go..
      Make sure if you use a CMOS based chip to tie unused inputs to either Vss or Vcc, or it's possible to damage them.. Or it was back when i was in electronics school anyway..
      • PeteS in CA
        • Aug 2005
        • 3578
        • USA, Unsure of Planet
        Their V(cc) have to match (74LS uses +5V). Beyond that, the 74LS has to be able to operate at the clock frequency for the uC. So you need to look at the max. operating frequency for the 74LS series.
        PeteS in CA
        • vsmGuy
          • Jul 2006
          • 28
          Very nicely answered !
          The ATMEL 89 series and PIC seem to have TTL compatible IO. Hence, LS should not be a problem.
          I was sorry I did not mention this, because I had a mind block with the clock freq.
          What I was querying about was whether anyone had speed sunc issues.
          LS logic hit the max at ~25Mhz whereas HC at ~65Mhz, unless I am mistaken.
          • byteexp
            • Oct 2006
            • 10
            i think there should be no problem mixing atmels or pic micros with other logic familys, LS are for low-speed circuit (4mhz?) while HC are for high speed circuits (20Mhz?)
            it will be based on the design and purpose of the circuit.
            • ugamazing
              Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
              by ugamazing
              I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
              08-31-2022, 07:34 AM
            • feherhollo
              WSON8 NEW Bios Chips READ, ERROR, ETC.
              by feherhollo
              I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
              I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
              For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
              11-26-2023, 09:33 AM
            • ohren
              Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
              by ohren
              I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
              I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
              The models launched in 2018 and 2019 respectively....
              09-08-2023, 05:24 PM
            • korben_dallas
              Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
              by korben_dallas
              Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
              I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
              I'm new to soldering but the only feasible way to fix this issue is to do something myself.
              MY QUESTION:
              I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
              02-14-2024, 12:23 AM
            • Yanleb
              LG 60PK550 Logic Control Board EBR63450301
              by Yanleb
              Hi all, I just want to share the repair of my 60PK550-UA TV set.
              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
              C57: 3.30V
              C61:...
              07-20-2023, 12:38 AM
