chaper alternative to CL1850 CLIFF (mains quick connection)
    This looks like a handy little tool for safely connecting to wires to mains while testing some device you're working on:
    https://ro.farnell.com/cliff-electro...test/dp/658716
    Or CL1860 CLIFF - image attached.
    But quite expensive for a plastic and some metal.
    I couldn't find a cheaper alternative.
    Do you know one? Or what other name can I google?
    Thanks.
    Re: chaper alternative to CL1850 CLIFF (mains quick connection)
    there are cheaper clones, even ones for the americans with their fucked up color codes,
    and even a 3-phase one.
    try aliexpress.
      I tried AliExpress with no success.
      I've tried names used by CLIFF.
      What search term should I use?
        looking at the prices, just use WAGO connectors
        https://www.youtube.com/watch?v=OP86SxqP7I8
          i have an old one of those safe blocks .
            i dont see how a bunch of spring terminals in a box is worth €60!!!!!
              Should be called a clive not a cliff connector... I never saw one 'till...
                I have one some where in my collection of odd items and when I find it again I was going to modify slightly to fit my way of wanting to use
                9 PC LCD Monitor
                6 LCD Flat Screen TV
                1 Dell Mother Board
                15 Computer Power Supply
                All of these had CAPs POOF
