Thinkpad Yoga LA-A341P BIOS
    I bricked my thinkpad yoga i5 convertible 12.5in while updating the BIOS
    The only way to recover is to flash the BIOS
    I need a BIOS image file - can anyone help
    Re: Lenovo Thinkpad Yoga 14 - BIOS Dump - TPM Security
    Does anyone have a BIOS image for a ThinkPad Yoga
    Motherboard LA-A341P
      I found this for anyone else out there you might need it
        Hi
        Could you possibly advise which chip is the bios chip on this board?
        Mark
          Programmed it on to the eeprom but the system keeps the password. Also the serial does not change.
          Do I need to flash another chip to remove the password?
            ty work"s for me
            OKBALORD
              Re: Thinkpad Yoga LA-A341P BIOS
              Any idea how to remove supervisor password from this motherboard?
              I flashed the bios and kbc but password is still here. Password is gone only if i remove the eeprom chip so i Think that the password is there but this is write protected chip and i cant do anything.
                LA-A341P : 2x bios and 24rf08 + EC
                LA-A342P : 2x bios and EC
                the 24rf08 or p24s08a reads very well, this eprom is not locked
                or bypass password with shunt on 24rf08 between scl and sda when backlight come and F1 to enter setup.
                  It work's, thank you!
                    please clean me region, this bios dump is working but late Display....
                      already done it for the others that need it!_!
                        i need dump to kb9012-A4 motherboard LA-A341P REV 1.0, can anyone help me please?
                          zips1 la-a341p rev 1a bios password reset
                          how can i clear password from zips1 la-a341p rev 1a
                            Re: zips1 la-a341p rev 1a bios password reset
                            see post #8
                              Originally posted by SMDFlea View Post
                              see post #8
                              thANK YOU
                                Lenovo LA-A341P REV 1.0 bios request
                                hello guys looking for lenovo LA-A341P REV 1.0
                                REV 1.0 Not the A1
                                  Re: Lenovo LA-A341P REV 1.0 bios request
                                  REV 1.0 Not the A1
                                  post the full name and model of the laptop
                                    Could you highlight the scl and sda in an image, also what is the optimal way to shunt it to unlock password, as the chip is rather difficult to access if the full frame is assembled
                                    thanks -M3troid
                                      my apologies, images loaded after a reload of the page, images clarify very well.
                                      did you initially use the bioshunger bios to achieve unlocked password, i take it this one is not ME neutered, i can achieve this myself once i arrive home
                                        i tried shunting after i had succesfully used the bioshunger files to troubleshoot that indeed the bios chip was being problematic, i then neutered IME from the original bios files and got it to boot, however i could never get past the bios password so i tried shunting it, with what i assume is very bad success as my laptop no longer boots, the fan speeds up fast shutsdown the laptop and repeats this process 3 times blinking the power LED, my assumption is from the attached images that this process somehow fried my onboard ram as the chip itself looks to be visually fine but ram chips have weird wear in them
                                        any remedies to recommend for this process or is my laptop just toast at this point i am indeed waiting to get a multimeter at this point to zero in on possible issues
