I am not sure where this should go, so please advise.... move as necessary.
I have two GQ's that are twins, purchased from Fry's. They both have the Macron PS. One box was getting blue screens and lockups. The other appeared normal, but it was not used nearly as much.
I removed the power supply and immediately noticed a half dozen 2200 uF 10v capacitors that ALL appeared to have bulged tops and a brownish deposit. There were no letters or labels other than weird looking G L. The G has a short extension at the base and the L has a longer extensions. Sort of like this:
G_L____ with a slight curl up at the very end. Marked 105C
They also had some white material I assumed was glue to hold them in place for soldering.
I replaced the caps with 2200uF 16v 105C caps with a H sitting on a circle or oval, which I had ordered from Acme Enterprises in FL.
From the short life, Nov 2006 to Jan 2009, I assume the caps are not very high quality. I emphasize that the second machine, not used very much at all, probably less than 20 hours, had the same appearance as the machine use in daily basis.
The caps I used for replacement were of a larger diameter than the originals, ~3/8" vs ~ 1/2", so they did not sit down on the pcb, and were more or less left on longer leads raised a bit from the board in some cases.
Did I just buy a little time, or did I use decent caps. I guess if they cannot put their name on the product, it is not of high quality.
I have not looked at the motherboards, but they are ECS model 741GX-M2.
tom
tom
