Zotac 1660 ti Shorted
    I just got that 1660 that someone shorted by touching a metal plate to the back of the card.
    I found that U15 (ALNB 9614) has a hole in it. Any idea what that is so I can buy a replacement?
    Also, all these caps in the photo measure 0.2ohm which I suppose is short, as this is what my multimeter measures ground to ground as well. Measurement taken after taking off the burned IC.
    PN 9288-3n527-201z8
    board id 23a-DN527-101AF
    Re: Zotac 1660 ti Shorted
    You can just about see the AO logo at the top left corner,its an Alpha Omega OZ2261NQI
    Datasheet - https://cdn.badcaps-static.com/pdfs/...db75a86549.pdf
    0.2ohms is short,maybe a shorted cap somewhere
      Thank you for that!
      All 3 marked locations are shorted, should I assume that's short to the vcore?
      Can I inject 1 volt in on any of the 3?
      Update:
      Injecting 1v gives 6a and warm GPU
