Help with smd capacitor test
    i try to test an smd capacitor out of circuit but get no reading how to do?
    Re: Help with smd capacitor test
    i guess you found a bad one .. maybe try test a new one .
      i did it with 11 other but it is same is all of them bad?
        maybe its your meter? try another meter?
          tested with what?
            Hi stj with multimeter in diode and ohms
              You really can not test capacitors correctly this way you at a minimum have capacitor checker at minimum but really need a ESR capacitor tester to do this correctly
              9 PC LCD Monitor
              6 LCD Flat Screen TV
              1 Dell Mother Board
              15 Computer Power Supply
              All of these had CAPs POOF
                you mean that it is not possible with multimeter or digital tweeser am talking about microscopic smd capacitors the ones on the tv screen boards
                  No capacitor can not be tested correctly just using diode test or ohmmeter
                  With just a ohm meter or diode test will only tell you if is shorted but nothing else really
                  Now if you have a capacitor tester that shows you UF value that is better than nothing however it does not tell you if the capacitor is good or not for this you need a ESR capacitor tester for this
                  This is the ESR capacitor tester that I use
                  https://www.ebay.com/itm/18423015559...QaAnBZEALw_wcB
                  9 PC LCD Monitor
                  1 Dell Mother Board
                    Thank you for the answer your tools is for proffs
                      There other versions of this ESR that cost less however the quality with some of them is questionable
                      9 PC LCD Monitor
                      1 Dell Mother Board
                        our tools cost about the same as a couple of beers in sweden after taxes!
                          You don't need to use that, the cheap "transistor tester" that has been discussed here and elsewhere works just fine and can be had for the same price as the cheapest beer you can find in Systembolaget.
                            oh stj,sam_sam_sam and Per Hanson thank you i have that cheap an will test and se.
                            tack Per Hanson glömde bort den den ligger nånstans jag skall söka
                              beer must have increased in price over the last few years - or the taxes increased!!
                                Oops, the quick glance on eBay fooled me: the prices where for empty cases etc.
                                So make it 10 beers then
                                  beer are not that expensive as it was even taxes Per Hansson can tell
                                  no not 10 beers Per just around 4 or 5
                                    ok i di some test and i get :28pF from both end of the capacitor and it does not show any esr so i can not know if it is good or not. the result is the same on all 12 capacitors
