Old 09-23-2021, 07:52 AM   #1
morind79
City & State: Poitou
My Country: France
Default 55PUS6031 Vestel 17MB120 reboot
Hi All,
I have a Philips TV 55PUS6031 that is rebooting all the time.
I heard it was due to the firmware that is corrupted.
So I have flashed a new firmware (that was for Philips using Vestel) so now the TV can boot normally.
But screen was rotated 180 but remote control is working fine.
I first thought I used the wrong firmware so used another one (that was for OEM using Vestel) but still the same.
But now I have another issue is the remote control is not working anymore !
So I cannot flash a new firmware as I need the remote control OK button.
How can I solve my issue ?
I would like to reflash the first firmware I have used.
I am able to connect to the TV via telnet (using Vestel toolbox), do you know if I can change the remote control settings ?
Thank you.
Denis
morind79 is offline   Reply With Quote
Old 09-24-2021, 03:13 AM   #2
ducky29
City & State: -
My Country: Europe
Default Re: 55PUS6031 Vestel 17MB120 reboot
Keep pressing ok and you should be able to flash the firmware even if your remote dosen't work. I know it dosen't make sense but give it a try. Then I can help you rotate the screen or I can find you the exact firmware for your tv.
ducky29 is offline   Reply With Quote
Old 09-24-2021, 03:47 AM   #3
yokoono
If the OK key is not functional, try a programmable remote control.
yokoono is offline   Reply With Quote
Old 09-24-2021, 05:13 AM   #4
morind79
My Country: France
thank you for your answers.
I tried OK button several times, but still does not work.
I have an old programmable RC I will try with that.
Otherwise, maybe there is a file I can modify to be compatible with the remote ?
I have access to the Linux files via Telnet.
Old 09-24-2021, 05:53 AM   #5
ducky29
City & State: -
My Country: Europe
Try another method. Press press press rapidly instead of holding it. Sorry I don't know any method via telnet.
Old 09-24-2021, 05:56 AM   #6
morind79
My Country: France
No luck so far :-(
Old 09-24-2021, 12:00 PM   #7
morind79
My Country: France
I finally get it working with a Toshiba remote control.
So I have set a new firmware and original RC is working again.
But still image is rotated 180 :-(
I try going in service menu, but without success for the moment.
Old 09-25-2021, 07:01 AM   #8
ducky29
City & State: -
My Country: Europe
Sent you a pm with instructions and files.
Old 09-25-2021, 05:05 PM   #9
hosbulduk
City & State: Recklinghausen
My Country: Germany
I'm a: Hobbyist Tech
hw profile file contains remote control settings. If you know how to change the code of your Philips remote control in the hw profile, if it becomes active again or if you find a Vestel TV remote control, your problem will be solved and the software you have installed will be applied to another remote control. , therefore the Philips remote control is not active The code is in the battery compartment.
hosbulduk is offline   Reply With Quote
Old 09-26-2021, 05:49 AM   #10
morind79
My Country: France
I have reflashed using a Toshiba remote control.
So the Philips RC is working now.
Still issue with flipped image.
Old 09-26-2021, 09:45 AM   #11
yokoono
Enter the panel code: VES550XXXXXXX.
Old 09-26-2021, 09:55 AM   #12
hosbulduk
My Country: Germany
It is possible to solve the mirror screen problem by installing the panel software. It is possible to find the software of TV brands made in Turkey on the Turkish forum by their serial numbers, the link I shared in another topic. But I solve the problem by just trying the panel software released according to the motherboard group on the export product TVs. Today I installed the mb170 android motherboard to the mb120 motherboard and got a mirror image.I have to look for the right software in the panel software.
[IMG]https://resmim.net/i/PEGK8
https://resmim.net/i/PE9f6[/IMG]
Old 09-26-2021, 11:05 AM   #13
morind79
My Country: France
The panel is : ves550qnds-2d-u11
Old 09-26-2021, 11:14 AM   #14
yokoono
Unfortunately I do not have a panel profile for 17MB120 and VES490QNDL-2D-U11.
Old 09-26-2021, 03:00 PM   #15
hosbulduk
My Country: Germany
No matter which panel you have, as yokoono wrote, you cannot find software by the serial number because it is an export production television. In this case, I'll try to find the right software by trying the panel software listed for my motherboard one at a time. When you search for "Tavsiyeforumu Panel yazilim" on google or click the panel software link I shared on other topics. You can use the software grouped by motherboard to access the panel software archive and try out the software suitable for your motherboard.
Old 09-26-2021, 03:35 PM   #16
ducky29
City & State: -
My Country: Europe
You are correct it might be very hard to find the firmware but I sent him the exact firmware based on the serial number. Tavsiye has only firmwares for vestel and other turkish brands and not exports like toshiba, philips, bush, luxor, jvc etc etc; which I can source. Nowdays theres a lot of variety in the vestel firwmare starting from rc, logo, panel, smart-non smart, sound, reception etc etc so its a pain in the ass trying to find the correct combination.
Old 09-26-2021, 11:47 PM   #17
morind79
My Country: France
With the latest firmware everything is working fine !
A big thank you for all your support.
Old 09-27-2021, 12:29 AM   #18
yokoono
1. So is VES550QNDS-2D-U11 no VES490QNDL-2D-U11
2. Do you not post here the used software?
Badcaps.net Technical Forums 2003 - 2021
