Need Asus Bios Dump x550l
    Can't find a working bios for:
    Asus Model X550L
    Mother is x550lc rev. 2.0
    Thanks!
    PS: Is there a way to generate a valid dump from official Bios download? (Which is only 6mb instead of 8)
    Re: Need Asus Bios Dump x550l
    here is
      Asus Model X550L
      Thanks!
      read and post original bios, it can be "fixed" with that 6mb file
      Im Back... sort of...
        Thanks, I'd rather fix it myself, I have advance "rusty" assembler knowledge (Z80, 8088, hexeditors, etc). Any suggestion of how to do that?
        (Sometimes I use Araxis Merge and Hex editor XVI32 )
        Anyway will test first the one ridamouh159 sent and report back.
          Only hex editor needed and uefi tool
          Download official bios, get rid of aptio capsule and rest paste in dump. Not hard at all but i write from phone, cant post link for tool
            Got PhoenixTool266 but not sure what to do next... If you can give a clue when you get home I would appreciate it, thanks!
              Unfortunately ridamouh159 dump didn't work.
              Mother is UMA, (without dedicated video chip)
              Original Bios dump is:
              http://www.mediafire.com/file/7w7jgg...ingoriginal.7z
              Here's a file drop to place the "fixed" bios:
              http://www.mediafire.com/filedrop/fi...cd6cfca58f8e30
                see here
                i made small tutorial and how-to
                https://www.badcaps.net/forum/showthread.php?t=60659
                please wote if you find it usefull or not
                  Thank you very much, downloaded two asus bios (x550l c with nvidia onboard and d without). "Fixed" original BIOS, but still black screen. Begining to suspect from the onboard ram.
                  Is there a way to disable it and try with a ram module on the slot?
                    Hi, need help with Asus x550lb. Motherboard asus x550lc rev. 2.0. What clock generator is there?
                      not working
                        Originally posted by ridamouh159 View Post
                        here is
                        Working for me Philippines
                          hi,
                          Asus x550lc Motherboard asus x550lc rev. 2.0. test ok
                          thank you so much
                            hi sir isidro i upload my non working bios to your filedrop. hoping you can fix it.
                              here is
                              working bios.thank you
                                Thanks ridamouh159 ,bios working
                                  works thanks
                                    here is
                                    Thank you very much, it worked
                                      Thank you
                                        Thanks sir
