Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 06-24-2020, 01:44 PM   #1
stj
stj's Avatar
City & State: Europe
Default m$ fucking W10 again
https://www.zdnet.com/article/window...ering-reboots/
Old 07-12-2020, 07:09 PM   #2
RJARRRPCGP
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
Default Re: m$ fucking W10 again
For me, the March, 2020 update was bad.
MSI B450 Tomahawk
Ryzen 7 "Matisse" 3700X
16 GB Corsair Vengeance LPX DDR4 SDRAM
XFX Radeon RX 580 8 GB
eVGA Supernova G3 750W
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 07-14-2020, 12:23 PM   #3
ivtec
ivtec
City & State: Fall River, Mas,
Line Voltage: 120-60hz
I'm a: Hobbyist Tech
Depend on the Hardware you have. if you have older PC Stay away from 2004 win 10 version,some apps don't work ,1909 version is
ok.
ivtec is offline   Reply With Quote
Old 07-14-2020, 04:22 PM   #4
BigTroll
BigTroll's Avatar
City & State: Jefferson
My Country: LAMBDA SOND
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
I updated to version 2004 on my asrock deskmini a300, and I did have problems, notably it would be a blank screen coming out of sleep, so I ended up removing the graphics drivers and installed a beta amd one, yes radeon drivers still suck but I don't know weather to blame them or windows 10.
My Computer: AMD Ryzen 7 2700X, Asrock X370 Killer SLI/AC, 16GB Geil EVO X DDR4 3000, 500GB WD Black NVME and 2TB Toshiba HD,EVGA GTX 1080 SC, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
BigTroll is offline   Reply With Quote
Old 07-14-2020, 04:54 PM   #5
RJARRRPCGP
Sounds like when Windows 98 SE kept crashing, won't wake up if I installed the third party monitor driver said to be from Phillips for the 107S CRT, which it turned out I didn't even need for going to 85 Hz on my cheap Phillips 107S CRT.
Of course, the early-2000s was also a time where the BIOS for AMD systems, seemed a lot more buggy! Soyo was possibly the worst for this!
It would keep crashing at low load and usually found the PC crashed, if I walked away! So, they had a BIOS that was said to be from April, 2001, which fixed that.
But there was a work around for the Soyo SY-K7VTA-B motherboard: (KT133)
Lower Vcore by -0.025V, IIRC.
Old 07-15-2020, 10:31 AM   #6
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
That is quite interesting.
My Server 2016 machine had its first ever BSOD a few days ago.
Maybe it is related to M$ fuckups then and not memory corruption as I feared.
I did run Memtest86+ and there where no errors found...
Bugcheck code was: 0x00000109
https://docs.microsoft.com/en-us/win...ure-corruption
Old 07-15-2020, 10:49 AM   #7
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
Yikes.... I just started test bedding S2K16 on a system....I haven't had this yet, but thanks for the heads-up.
After a round of updates on S2K12, Starcraft1 and AoE don't run anymore. Spit out an error on startup, no idea what's causing it.
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 07-15-2020, 01:18 PM   #8
ivtec
ivtec
I just did not try to find out why some apps did not work on 2024,i just reverted to older version 1909 and all was good ,and as they say if it works good don't change.
Badcaps.net Technical Forums © 2003 - 2020
