I have Samsung NP350V5C laptop that boots directly to bios. I have removed keyboard and all peripherals, cleaned the board but it always starts up to bios only. Even after exiting bios it restarts again into the bios.
Samsung NP350V5C boots directly to bios
Re: Samsung NP350V5C boots directly to bios
It's normal behaviour on a lot of UEFI systems when there's no system to boot. (no storage drive, no UEFI bootloader, or boot menu entry missing)OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
go to bios then check all the peripherals there including the hdd sdd or boot device unchecked the secure boot.. try legacy boot if you have a brand new hdd. or try to reset it using load default settings.. then reboot.. check also the bios rtc battery 3v .. gud luckNever stop LEARNING because life never stops TEACHING!
Originally posted by piernov View PostIt's normal behaviour on a lot of UEFI systems when there's no system to boot. (no storage drive, no UEFI bootloader, or boot menu entry missing)ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
You guys it still does this with a working, or blank or even an OS installed hard drive in there. I have removed the keyboard, reset the bios to defaults and it still does this. I have even taken it apart and cleaned the board with alcohol and it still happens.
Originally posted by SuperAman View PostYou guys it still does this with a working, or blank or even an OS installed hard drive in there. I have removed the keyboard, reset the bios to defaults and it still does this. I have even taken it apart and cleaned the board with alcohol and it still happens.
