Acer aspire v3-371 BD-Prochot problem
    hello
    i have this laptop that turn this on one minute after booting up
    since i replaced the OS (used linux ) and the power adatapter did all kind of tests cpu temps or any temps are low not high enouth to make the cpu activate and only solution i know of is using the program to disable bd-prochot
    this may be a hardware problem i question is do i get shematics for it and will be something that can be fixed?
    if its inside the GPU/CPU chip since its a i5 only replacing the cpu will solve it?
    any other sensor that is malfunction would make temp data show wrong values
    thank you for reading this and for any tip you can provide
    Rictec
    Re: Acer aspire v3-371 BD-Prochot problem
    What is your mb code?? Is it VA30??
