Hello guys, I really appreciate your efforts in this community, as I often read the discussion and find good solutions here. It is my turn this time, so a question for you on this very common BN44-00264A power board by Samsung.
My TV LE40B650 is not working anymore, no backlight and no standby led are present. I started to check some components, also reading past discussions about this board.
- fuses are ok
- CNM802 readings all 0 volts
- no backlight appears when disconnecting logic and power board
- QI820/21 not shorted, pretty high resistance on pins 1-2-3
- capacitors not swallen, at least inspecting them while onboard
- no burning signs but some rust on QP801S and 802S solder joints, I think they still make contact, maybe I can test them if you tell me what to measure (see the image).
Any additional tests that I can do to solve my issue? Thank you!
- fuses are ok
