Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices > BIOS Requests ONLY!
Thread Tools Display Modes
Old 10-13-2021, 03:36 PM   #21
Bb68
City & State: Durban
My Country: South Africa
I'm a: Knowledge Seeker
Default Re: T2 Chip Programmer Tool
Quote:
Originally Posted by stevie View Post
attached are the bin files from the T2 activation
you can run the mina activation tool by putting the MacBook Pro in DFU Mode
but unless you pay the unreasonable $90 to $120 that mina resellers
want for letting you submit the serial you want to use
it will come up with the message "serial no authorised"
you can use the tool with the bin files with the tool but although
successful it will give wrong summary details in about this mac
ie: displays that it is a 13" when it should state its a 16" etc
Hi is there new t2 unlock files available?
Bb68 is offline   Reply With Quote
Old 10-15-2021, 08:10 PM   #22
andriyd1
City & State: new york
My Country: USA
Quote:
Originally Posted by MughalG View Post
i have good working Activation_Lock bin files for all models with same configuration as per model
of course method is not for free
New serial number / WiFi/ Bluetooth address already built into it?
andriyd1 is offline   Reply With Quote
Old 10-18-2021, 04:41 AM   #23
curiositymaster
City & State: Lagos
My Country: Nigeria
I'm very sure you've got a lot of free help on this forum, I mean from people who didn't get the knowledge/tools free of charge.
curiositymaster is offline   Reply With Quote
Old 10-18-2021, 04:41 AM   #24
curiositymaster
City & State: Lagos
My Country: Nigeria
Quote:
Originally Posted by anhbanxoi View Post
I cannot open minaT2Activator on Macbook M1. Anybody tested that file?
Use it on an intel-based system.
Old 10-18-2021, 10:14 AM   #25
paulyboy
City & State: auckland
My Country: New Zealand
What programmer interface for reading the chip please? Is the a socket for tl866 thanks
paulyboy is offline   Reply With Quote
Old 10-19-2021, 01:14 PM   #26
Bb68
Quote:
Hi
Ch340 programmer , like by-t200
Old 10-19-2021, 06:38 PM   #27
Trackstar23
City & State: Chandler, AZ
My Country: United States
Line Voltage: 120VAC 60Hz
Any programmer that can read/write to a 25 Series SPI FLASH should be able to interface with the T2 ROM. The CH341A chipset is utilized by most popular products that were developed specifically for the T2 ROM, but a TL866 should also be able to read/write to it so long as you use a 1.8v adaptor when reading it (or use an adaptor that has the 1.8v conversion logic built in).
Trackstar23 is offline   Reply With Quote
Old 10-20-2021, 05:04 AM   #28
MughalG
City & State: rawalpindi
My Country: Pakistan
Quote:
Yes sure already modified
BR
MughalG is offline   Reply With Quote
Old 10-20-2021, 05:06 AM   #29
MughalG
BY-200 is best for now, anyway you can read it with any programmer but need to solder points
BR
Old 10-20-2021, 05:17 AM   #30
MughalG
M1 Not supported
Old 10-20-2021, 04:27 PM   #31
Blackmambo50
City & State: montreal
My Country: Canada
Hi there, after using this kind of bypass (flashing the spi flash)
I have two issue: first is that mina/checkm8 give an error, something like "was not able to read from your t2 mac"
And if i try to online restore it, i let me put the password for wifi, but after that it does nothing...
Any advise?
Blackmambo50 is offline   Reply With Quote
Old 10-20-2021, 05:06 PM   #32
Blackmambo50
My Country: Canada
Ok after flashing spi back to stock, machine seems to pass this step witch make be belive that either its the issue with mina/check8 or maybe those sn are now blocked by apple...
Old 10-20-2021, 10:30 PM   #33
paulyboy
anyone know the socket for the rom
Old 10-20-2021, 11:05 PM   #34
anhbanxoi
City & State: Ho Chi Minh
My Country: VN
USON8 4x3mm
anhbanxoi is offline   Reply With Quote
Old 10-21-2021, 02:04 AM   #35
Bb68
I think the T2 unlock data for A1932 is blocked, that Serial number in the T2 unlock bin may be blocked now by Apple because cannot restore in Apple Configurator 2. Can anyone confirm if they have used it recently ?
Old 10-26-2021, 07:42 AM   #36
curiositymaster
City & State: Lagos
My Country: Nigeria
Maybe something is wrong with the file you're using. Try using your stock bin file with a Mina-fied (if you get what I mean) serial number, it should work.
Old 11-01-2021, 07:11 PM   #37
david zhao
City & State: sydney
My Country: australia
I used T203 for A1932 2018 model on 20/10, it worked well. Then I tried to use it for my A2179 2020 model, it gave error "not found SSH device, check it and try again". I got this error at the last step while the "minaT2activator" started running? anybody else has the same issue? Please share your solutions.
One more question here: Can we modify the serial number in those unlock data bin file, before we auto program the rom chip? Will the changing of the serial number affect the jailbreaking?
All helps and discussions are welcome.
David
david zhao is offline   Reply With Quote
Old 11-01-2021, 07:25 PM   #38
david zhao
Quote:
Originally Posted by Stephen View Post
I was curious if the T2 chip serial being changed would allow cracking the Firmware lock and icloud lock of a device? We came across the T2 Rom Tool and this allows the use of changing the serial which in our experience would allow removal of MDM on older models (2017-and older). Would that isolate the icloud bypass since it is married to the serial of the T2 chip? Curious since we are close to pulling the trigger on a wholesale lot and we anticipate iCloud devices in MacBooks etc. Piernov or anyone have thoughts on this?
Update: People are saying yes and no. If you change the serial you would have to change the UUID? Apple looks at the serial and the UUID in the rom. I know we could figure this out some how some way.
Any answer to this original question? If I modify the serial number in the unlock data bin file, will the iCloud bypass still work?
Old 11-02-2021, 09:17 AM   #39
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
Hi. Also interested to learn if the T203 tool is suitable to remove password off A1932. Looking to purchase a broken A1932 from Ebay but only if we can get the password off the unit. Real focus is to learn on how to remove and replace the very thin LCD retina as compared to replacing the display assembly.
mon2 is offline   Reply With Quote
Old 11-03-2021, 01:54 AM   #40
gmorb
City & State: san diego
David
Same happened to me for my A2179. SSH error
gmorb is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
