need bios la-e331p
    need bios la-e331p
    need bios la-e331p
    Re: need bios la-e331p
    post the original bios, laptop, model, motherboard, etc
      Dell XPS 15-9560 CAM00/01 LA-E331P
      Hi to all
      May I have a request for this Bios bin File this Unit
      Unit Brand Model and Mobo Part no.
      Dell XPS 15-9560 CAM00/01 LA-E331P BIOS
      Also i Confused for the Following ROM Or Bios Chip
      UT2_W25Q80
      UT5_W25Q32
      UH8 W25Q256
      Which one is a Main. I guess Only UH8. also I dont have a Socket Slot Kits
      for Frashing this Type of ic. but i know howto identify the Pin out. also may i know if the RT809F Can support This type of Bios CHip?
      other info about this Laptop. Problem is Auto off, i press the Power Switch . Light indicating then the Device Turn on no display . fan spinning Normal then about 9 to 10 sec. turn in off.
      TIA
        Re: Dell XPS 15-9560 CAM00/01 LA-E331P
        Bios - https://www.alisaler.com/dell-xps-95...e331p-bios-ec/
        Schematic - https://www.badcaps.net/forum/showthread.php?p=946795
        EDIT: the schematic is for the LA-C361P ,not LA-E331p
          Thanks Boss
            Dell m5520 bios needed
            Plz i need working bios of this MB thanks in advance.
            Part no. CAM00/01 LA-E331p rev 2.0
            Dell precision M5520
              Re: Dell m5520 bios needed
              post the oryginal bios
                Dont have original bios some other technician erased orginial bios
                  No one can help?
                      Your serial !
                        Serial?
                          yes , you find it at the backup
                            Need la-e331p rev 1.0 bios
                            Model : Dell xps 15 9560
                            motherboard code : LA-E331P REV 10 (A00)
                            Please clean me bios dump.
                            orginal bios no screen :
                              Re: Need la-e331p rev 1.0 bios
                              Try and reply please
                                not working
                                  try..
                                    how can i find it in bios? what should i search in HxD?
                                      i found 1 bios which worked but laptop was turning off in 15 to 20 seconds, i tried reprogramming ec but then same issue came up NO Display
                                        Try to clean me this bios
