bin asus s510u x510ur
    please any body have de dump file for asus s510u x510ur NB0FY0-MB4120
    thanks you so much
    Re: bin asus s510u x510ur
    no one? im looking for this bin too
      post your original backup then someone will rebuild it for you
      There are 10 types of people in the world. Those that understand binary and those that don't.
        there u go
          try this repaired file
            with your original windows key
              thanks
                Originally posted by el panke View Post
                there u go
                thank you dear...
                  Please can someone help bios it is ok but there is a display after 36 seconds can someone fix me this problem thanks
                    Originally posted by pcpartrepairlab View Post
                    please can someone help bios it is ok but there is a display after 36 seconds can someone fix me this problem thanks
                    try
                      Thanks works great
                        Hello, I have This model with power light but no display.
                        S510UA-BQ476.
                        I think is a bios issue. Someone can help me? THANKS!
                          S510UA-BQ476.
                          try..
                            I have a similar problem with my asus S510UA. Power light blinks one time when I power it on and then nothing.
                            I think it's a bios issue. Can someone fix this?
                            Thanks!
                              Thanks!
                              the posted bios is not ok..read the bios chip again and post ..
                                Thanks for the fast answer!
                                I tried again and the extracted bios was indeed different from the first one. Hope it will be fine!
                                  Your file is still not ok.
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                    remove the bios chip from the motherboard before reading or writing..do not use the clip, you may have errors..if you can't remove the chip, solder wires between the chip and the programmer ..
                                      I removed the chip and soldered directly on my programmer. I selected the right chip (W25Q64JV).
                                      But at first look, it seems that I have the same extract than the first one...
                                      Maybe a faulty BIOS chip?
                                        The programmer has a problem or the bios content has been changed with a junk file.
