Bios dump for Toshiba L775D-10v
    Hi guys,
    Since the laptop was doing strange things, powerled on in the night while not on ac power for a couple days until i remove the battery
    and later on no picture anymore so i guss that its a faulty bios
    i tried a other pegatron bios, goes on and off but still no picture, all voltages come up
    This one is with a AMD A6 processor and GPU in the processor
    And a 2mb bin file !! only 1 eeprom
    Toshiba sticker; PSK40E-04602FDU
    Motherboard p/n; 08n1-0n93j00
    Rev.: 2.1
    Thank you all
    Re: Bios dump for Toshiba L775D-10v
    Originally posted by Michiel View Post
    Hi guys,
    Rev.: 2.1
    Thank you all
    try..
      power led is on but battery led is showing white and orange at the same time, not responding on power button
        Try this bios PSK40E
          Yes! thats the one
          i First powered on the laptop and it did not show any picture
          i heard some kind of reset after 10 secs the dvd drive init again
          I turned it off by holding pow button for 7 seconds
          i removed 1 ddr3 memory
          turned it on with pow button and works ok
          added the same ddr3 again and all 4gb is gecognized ok
          works for about 1 hour and turned it back off
          all was working normally
          but after putting it on again no picture anymore
          i compared the old bios files with Winmerge, but they seem to get corrupted
          now i dont get it back to life anymore
          here are the bios dumps after using the laptop; it worked 1 hour with old2.bin
            The only difference is no DMI in the bios i posted and NVAR which won`t be written until the laptop is booted. Ive added the DMI and you can try it,if the problem persists its something else,the bios is good.
              I still have problem with the laptop showing no picture
              But it is running now for a couple hours working ok
              And can shutdown it now without problems
              I hope problem is gone now
              When it jams the wifi light stays on
              When it posts ok the wifi led goes off and then on and
              runs ok
              Ive made a picture of the bios , it is showing main and ec bios versions, is this ok because the laptop has only 1 eeprom ?
                Found the problem! One of the USB ports 5volt was shorted!!
                  mine only show wifi led orange, cpu cooling fan spin, no video xd
