Sony kd 55xf7596 fading picture
    Hi all got a problem with 55 Sony led. Tv
    Model is kd 55xf7596 the TV turns on to a full screen
    Then after 30 seconds or so the picture fades
    Away like a dissolving effect back-light still lit
    I've removed left side tcon flex ribbon and screen stays normal but flickers when the tcon heats up
    So first port of call was to change tcon
    So after. Replacement the TV does the same
    I must stress there is no water damage or panel being banged at all this fault just devoloped
    Any ideas please
    Re: Sony kd 55xf7596 fading picture
    If you can take a picture of the screen fadinng that will help a bit understand what you are looking at.
    But this one is going to be a clear cut case of good ol bad panel with a side tab tear down.
    Remove the bezel, and remove the tabs on the side that is affected. Should clear it right up.
      Merits more testing, one bad capacitor could give the same symptoms.
        It doesn't have side tabs matee
          this is Android Set, one of the android TV disadvantage need time to time to clear Cashe as it lager it day after day specially if there much playing with apks.
          make hard reset ( Not from menu setting menu ) by pressing power and volume - while plug it in wall socket release them after the LED changed from While to green.. also apply update if there available... recommend after any upgrade doing hard reset always the best way to have clean smooth system
            possible LCD panel problem
            Never stop LEARNING because life never stops TEACHING!
