panasonic tx-p50gt30 8 blinks afrer 7 blinks repair
    Hello again.
    I have a little problem with my tv: it had the 7 blinks failure, and I repaired the SC board. After that, it starts for 1 second and goes to 8 blinks. Everything on the SC board looks to be fine but I discovered that I have one shorted transistor on the SS board, Q102. I have a new one but I am wondering if it would be better to replace also IC 191.
    I did not check the SS board before the 8 blinks. Do you think it's possible that it went off together with the SC board or it died after my repair?
    Re: panasonic tx-p50gt30 8 blinks afrer 7 blinks repair
    You should be fine with replacing Q102 only. I've had this fault myself.
      Ok, thanks. I'll give it a go.
      Have you found the cause of this double failure?
        Just the loose screws that mount the boards.
          Yeeeee! It's alive!
          It was only Q102 on the SS board.
          The SS screws were not loose. On the SC yes, they were loose, almost all of them. I had some screws with washers and replaced all of them.
            Good job! Those damn screws have kept a pretty good supply of cash coming my way.
