Ps59d8000pta
    Ps59d8000pta
    Hi Guys,
    I have an issue with this Samsung Plasma tv
    PS59D8000PTA
    Continuing on from previous thread as below
    https://www.badcaps.net/forum/showthread.php?t=87599
    NO PICTURE NO SOUND
    ok I have done the following
    checked all the power supply board All present at the supply board to the Main Board
    PROBLEM
    VS=7v VE=20mv VA=10mv measured at the SMPS TP
    SO here lies the problem
    I have replaced the power supply board as I thought that was where the fault was
    NO fix
    So I disconnected the Ysus and Xmain plug at SMPS i then followed the service manual TEST
    disconnected supply at main and shorted pin 1pON-GND and jumper pin headers
    Ok so VS 217v for a split second then falls to 0V
    VE is present then falls 0V
    VA is present then Falls 0V
    I have 15v at the SMPS YSUS PLUG pin 5 but that's it NO VS NO VA Supply
    So power supply is ok
    so I checked for shorts on XMAIN board and found shorts on BGT transistors
    So I replaced the board
    Still no go so I checked for shorts on YSUS board and found shorts
    Replaced the YSUS board
    Still not fixed
    Checked the Ysus Buffer Boards for shorts with floating GND method
    NO Shorts
    So now I am questioning Logic Board
    I have a red standby light then when I switch on a Green blinking light and when I check P-ON VS-ON it responds when I turn the remote on but immediately shuts off VS-ON
    I can hear the power supply board clicking on relays 2 clicks like on then back off
    So I guess there is still a short pulling the VS-ON down
    Could it be the Lower Buffer Boards or am I missing something obvious
    Thankyou for your Help
    Last edited by wazzadj@hotmail.com; 10-27-2020, 06:03 AM. Reason: forgot to add please can you help thankyou
